inline vacum filter for map sensor
Old Mar 7, 2012 | 08:42 PM
studabear's Avatar
studabear
Default inline vacum filter for map sensor
Does anybody know where I can get a inline vacum filter for my map sensor, and boost gauge.
Just in the middle of a megasquirt conversion and the instructions say I require 1.
Also at idle my boost gauge flickers like crazy till the rev's are increased.
My vacum setup is from the local hydraulics supplier, spring loaded push fit type/
Any help would be great.
Stu
Old Mar 7, 2012 | 08:46 PM
Mark V8's Avatar
Mark V8
Are you running throttle bodies or a plenum ?
Either way this will help
http://www.ebay.co.uk/itm/6MM-MINIMO...item415e828e34
Old Mar 7, 2012 | 08:53 PM
studabear's Avatar
studabear
a plenum, cvh turbo engine.
Cheers for the link, will that be ok with 20-30 psi through it?
Old Mar 7, 2012 | 09:00 PM
Mark V8's Avatar
Mark V8
I would have thought it would hold up to the pressure OK, you could always buy a couple and destruction test one with an air line
What MAP sensor does your MS have ?
From what I remember they do not go up to 30 psi as standard...
Old Mar 7, 2012 | 09:11 PM
studabear's Avatar
studabear
its got the 21psi map sensor to start with, it can be updated at a later date. When i get bored or a better clutch.
Self distruct test should be easy enough at work with the compressor and tyre gauge lol
Old Mar 7, 2012 | 09:12 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
this is what audi saw fit, just a simple small version of a fuel filter
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
stevecfrst1
Sep 30, 2015 05:18 AM
