4x4 saph not starting
Old Mar 7, 2012 | 08:14 PM
OrionRST200bhp's Avatar
OrionRST200bhp
Default 4x4 saph not starting
hi, got a problem, my saph is playing up, got fuel coming to the front, i took a plug out and it was wet. i had the car turned over while i held the plug held on the manifold and there was a spark. but it dosent start, weird. got new leads and new denso plugs. after i turned it over a few times i heard the coil making a few noises then i heard a sparking noise from inside the dizzy. could the coil be up the creek.
Old Mar 8, 2012 | 04:21 AM
Phase sensors tend to go faulty in the dizzy caps.The plastic on rhe wires become brittel and then the wires start to touch each other.
Old Mar 8, 2012 | 06:46 AM
stephenbatey's Avatar
stephenbatey
As Glenn has said phase sensor would be my first thing to check.
Old Mar 8, 2012 | 02:32 PM
charlie luciano's Avatar
charlie luciano
Check the water temperature sensor too its in a pig location unfortunately on the back of the head on the oil dip stick side
Luciano
Old Mar 8, 2012 | 07:16 PM
OrionRST200bhp
i forgot to say, it has a new phase sensor and a new cranck sensor. ive been told that it could be the starter. the starter has become lazy it sounds like its turning way to slow.
Old Mar 8, 2012 | 07:25 PM
daz1968's Avatar
daz1968
If you just fitted a new phase sensor recheck the gap on both heels and double check crank sensor gap and check timing, also make sure all connections are good, I had similar problem a couple of years ago took ages but ended up being one of the above although as I checked everything not 100% sure which it was but likely to be one of them. Easy to disturb something when changing the phase sensor especially if you had the distributor out. Also are you sure you have the phase and crank sensor connected to correct plugs as also easy to get these mixed up
Old Mar 8, 2012 | 07:34 PM
OrionRST200bhp
the sensors etc were changed before i went to M.A.Developments mark set the car up nicely so i know thats all fine, that was roughly 1k miles ago so that should be fine.
Old Mar 8, 2012 | 07:37 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
check the gaps anyway just in case.
Old Mar 9, 2012 | 12:31 AM
qad's Avatar
qad
call the help line joe@ gsmotosport
DixieTheKid
Jul 23, 2023 10:16 AM
jdsjojo
Aug 30, 2015 07:48 PM
jdsjojo
PassionFord Swap Shop.
Aug 26, 2015 09:51 PM
Old ford
Jul 31, 2015 06:50 AM
