Zetec Engines
Old Mar 7, 2012 | 08:07 PM
Jeffers_RST's Avatar
Jeffers_RST
Default Zetec Engines
Hi all, the story is that im mid build of a zvh, i had a silvertop block, had it all painted, skimmed, honed, crank work done etc, when i took it to my mate to be built, noticed it had a gouge out of the bore on no.3 cylinder, essentially making it scrap. I bought another block already modded for zvh told it was a silvertop but wasnt but had been modded already so bit the bullet. Ive done some searching on here but cant find exactly what im looking for. What i really need to know is, can i use my crank from the silvertop as its had work already and the rods i have. Is anything else different?
And another thing is that obviously i bought a silvertop oil pump from burton i sent it back to swap for blacktop but they cant get hold of any, so where would you recommend i get one from, would you pay £197+ vat for gen ford one for peace of mind or go motorfactors/ebay for a pattern one??
Cheers in advance and sorry for the essay!
Neil.
Old Mar 7, 2012 | 09:55 PM
nevsrevs's Avatar
nevsrevs
they wont be much diff now between a gen or pattern pump, but your best bet is to get a good used one, clean it and check for scores on gears and check the p.r.v is clean and working fine,
Old Mar 7, 2012 | 10:00 PM
Jeffers_RST
i dont think i could honestly sleep at night knowing ive put a second hand oil pump on the engine
Old Mar 7, 2012 | 10:16 PM
nevsrevs's Avatar
nevsrevs
better than having shattered gears, there has been alot of debate on this topic, the metal that they use in the new pumps is not up to the job really, this is what i have done on our build, the next step is a dry sump, i would not buy a new pump from any where now.
Old Mar 8, 2012 | 02:57 PM
Jeffers_RST
True i suppose! Give me something to think about i know theres been alot of discussion on it! Can anyone else expand on anything else ive written. Cheers
Old Mar 8, 2012 | 05:07 PM
7xrskb's Avatar
7xrskb
Silvertop and Blacktop cranks are the same so will be ok.
If you are interested I have a brand new Blacktop oil pump from an unrun bottom end (genuine ford)
Old Mar 8, 2012 | 05:13 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
cranks are the same, oil pump, well i run a 70k one, original are the best, as long they are stripped, cleaned and made sure there are no issues with them.
Old Mar 8, 2012 | 05:37 PM
Jeffers_RST
@7xrskb cheers for that, im definitely interested in the oil pump, how new is it, or should i say how long ago was it purchased?
@xr2wishy cheers for the heads up im surprised to see so many using old pumps but makes sense what u say dont make em like they used to. Lol.
I take it conrods are also the same?
Old Mar 8, 2012 | 05:41 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
con rods aren't the same, neither are the pistons, but you only need to match pistons and rods, i.e. both blacktop together or silvertop.
blacktop type give better revving due to longer rod and shorter piston height.
Old Mar 8, 2012 | 05:49 PM
Jeffers_RST
Oh right ok well iv got wossner zvh pistons and pec silvertop rods is this setup gonna work? Cheers
Old Mar 8, 2012 | 06:16 PM
ST Turbo's Avatar
ST Turbo
Stick to blacktop piston and rods in a blacktop engine or your comp ratio's might be little out! Not sure which rod is shorter, but you could end up have a rather low comp ratio!
Old Mar 8, 2012 | 06:28 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
there's some confusing info.....
the silvertop pistons are taller to match the shorter rods, blacktops have longer rods, but shorter pistons, in effect they are identical matched pairs in length.
you can use silvertop rods and blacktop pistons as this gives the lowest CR, if the pistons are meant for a silvertop engines rods, then stick to those, otherwise you will find the piston hitting the head.
Old Mar 8, 2012 | 08:14 PM
7xrskb's Avatar
7xrskb
Bottom end was purchased new from fords 2 years ago but never got used.
Old Mar 10, 2012 | 12:27 AM
Jeffers_RST
Ok mate drop me a pm and we will go from there. Cheers.
Old Mar 10, 2012 | 12:38 AM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
The first Zetec i built i bought an oil pump from ebay it was an "autopumps" make. But sold the engine befor i got it running. Then i built a cvh engine for some one and ordered a "high presure" oil pump from burtons when it arived it was an autopumps one with a different spring lolol. And a friend of mine built a zetec turbo with a new burton pump yup was an autopumps one lol. Ive fitted a 60k oil pump from an escort gti and its now gone on to 415hp with no problems the new ford pumps are crap!!! An old low milage pump is the way to go IMHO
JoeyBoyden
Jan 4, 2024 02:36 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
