Mondeo 1800 graphite Duratek engine
Old Mar 3, 2012 | 10:21 PM
broncolane5352's Avatar
broncolane5352
Default Mondeo 1800 graphite Duratek engine
Hi had a problem car has engine management light on,is missfiring all over,stalls on idle,mileometer needle rises when reving up,have fitted new plugs and leads,please help
Old Mar 3, 2012 | 11:15 PM
wirralphil's Avatar
wirralphil
What year is the car?
Old Mar 4, 2012 | 07:57 AM
broncolane5352
Default hi
it is on a 02 plate
Old Mar 4, 2012 | 08:01 AM
broncolane5352
it is on a 02 plate also do you know where port for data error reader is located
Old Mar 4, 2012 | 08:48 AM
DazC's Avatar
DazC
Coil packs are common.
The DLC is mounted above the throttle on the edge of the dash in a pull down slide.
Old Mar 4, 2012 | 08:57 AM
broncolane5352
hi thanks,so do you think it needs a new coil pack
Old Mar 4, 2012 | 09:07 AM
wirralphil's Avatar
wirralphil
Yes, replacement ones are around Ł50
Old Mar 4, 2012 | 11:21 AM
broncolane5352
thanks
Old Mar 5, 2012 | 12:51 PM
broncolane5352
Default help with coil pack
hi thanks for your help is it hard to change coil pack diy have ordered one can you advise Also have a mate lending me the data reader is the port the silver like box it has a plastic black grill cover over front with a small bolt to remove.
Old Mar 5, 2012 | 08:16 PM
James998's Avatar
James998
Coilpack is only 4 torx bolts to change. The 16 pin diagnostic plug is near where your knees would be, have a look just under the dash, it slides downwards. Nothing needs to be removed to access it.
Old Mar 5, 2012 | 09:34 PM
broncolane5352
Hi changed coil pack was no different put old one back on now won't start just turns over,had to put jump leads on still won't start,on benefits can not afford garage
Old Mar 5, 2012 | 10:37 PM
wirralphil's Avatar
wirralphil
Silly as it may sound have you replaced the leads in the correct way?
Have you the old plugs? if so post some pics up.
Old Mar 6, 2012 | 07:03 AM
broncolane5352
hi had plugs fitted by garage and leads was ok but was still missfiring ect can you give me your e mail will take pic of engine and send you
Old Mar 6, 2012 | 09:25 AM
broncolane5352
Hi done all l can ,still not starting turning over any ideas
Old Mar 7, 2012 | 05:17 PM
broncolane5352
Have car stood now,turns over not going any ideas
Mark Mawson
Aug 31, 2015 07:09 PM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
