Do i need a new cluch for my ford mondeo ST24 V6?
Old Mar 3, 2012 | 03:47 AM
floodyboy's Avatar
floodyboy
Question Do i need a new cluch for my ford mondeo ST24 V6?
I have a ford mondeo st24 v6 2.5 litre R registration - 1998 i don't think it's been modified. When bought on 29th feb it was working fine and then a day later i went round a corner and it just stopped without warning you normally get a warning when the cluch is going but i could get gears but couldn't get cluch to bite, there was a little bit of smoke but nothing like a burnt out cluch and no smell like a burnt out cluch there was a little bit of smell but when a cluch burns out it stinks. I can get it started and put it in to 1st, 2nd, 3rd, 4th, 5th and reverse gears with foot on cluch but, when i take foot off of cluch to drive it won't drive in any gear. But i can sit and rev as normal as though it was not in gear. The car got an mot at the end of september 2011 and there was a new cluch fitted so it shouldn't be gone already as it has been hardly used. Will a whole new cluch need fitted or is it something else? Can someone please help/give advice. I need advice/help as every garage is telling me diffrent things such as new cluch, disks, full hydrolic cluch kit and fly wheel? And is it worth fixing? I know nothing about cars as im a heating and plumbing engineer so can someone give me guenuine honest advice please it would be much appreciated, thanks Ray
Old Mar 3, 2012 | 09:23 AM
tomanycosworths's Avatar
tomanycosworths
If the clutch pedel feels normal then it could be drive problem, diff, gearbox or the centre has broken in the clutch, worth checking your drive shafts as some times they pop out of the cv joint.
On the plus side i have almost the same car for breaking so if you want any parts let me know and i will do you a good deal.
Old Mar 3, 2012 | 09:30 AM
bad boy rs's Avatar
bad boy rs
get in contact with the company that changed the clutch in sept, if youve hardly done any miles surley its down to them
Old Mar 3, 2012 | 01:06 PM
floodyboy's Avatar
floodyboy
thanks for the advice gettin AA out to have a look as soon as we find out what part we need we will give u a shout
Old Mar 3, 2012 | 03:03 PM
Madgit's Avatar
Madgit
Works and plays on track
Who'd you buy it off? They'd be getting it back if it went wrong the next day. Were you driving sensibly or giving it some?
Old Mar 3, 2012 | 04:36 PM
floodyboy's Avatar
floodyboy
cousin didn't even go over 30 mph didnteven do 5 miles my cousin did 5 worked perfect he wasn't thrashing it either
Old Mar 3, 2012 | 04:40 PM
floodyboy's Avatar
floodyboy
is it a big job to pop the drive shafts in to the cv joint or could the AA do it?
Old Mar 3, 2012 | 05:39 PM
Madgit's Avatar
Madgit
Funny I was thinking driveshaft, that's why I asked how it was being driven.
Old Mar 3, 2012 | 05:53 PM
bookwyse's Avatar
bookwyse
Sounds like the diff has gone which s very common on them.
Old Mar 3, 2012 | 09:10 PM
2wd saff cos @ stage 3's Avatar
any pics or details of that on here?
borboyous
Aug 22, 2015 11:17 AM
