Advice on painting car parts (freshen up)
looks for advice,
would like to freshen up the underside of the car,
wishbones
rearbeam,
drive shafts
boot floor
subframe
arb
etc
whats the best way to do it?
what to use?
temperature for example
bare in mind, i have a normal garage and not a spray booth
and i dont have a compressor
will rattle cans be ok, or am i better getting them done professional?
wishbones
rearbeam,
drive shafts
boot floor
subframe
arb
etc
what to use?
I'd borrow hire a compressor mate , take the rust spot off with
Wire wheel or flap wheel , etch it then if it's the 205track car
Just use white stone chip.or 2k white on top of it if u want a paint finish
When I painted the underside of another car, I wire brushed and treated any rust or flaking stonechip, then wiped all underneath with degreaser to make sure clean, gave it a good coat of zinc primer with a brush, seam sealed with brush on sealer and used a aerosol stone chip where required, then to finish it off I had some synthetic enamel mixed to car colour and applied this all underneath with a small gloss foam roller, due to ripples in stonechip it looked as good as spraying over it and has lasted very well. Only really worth spraying if doing concourse in my opinion. Beam and arms etc are better being blasted and powder coated.
