Ford Puma Discuss the Ford Puma here!
Door ajar light on
Old Feb 26, 2012 | 05:44 PM
Garry Giles's Avatar
Garry Giles
Default Door ajar light on
Hi All
Ive got a 2000 plate 1.7 Puma. In the last few days the door ajar light has been on constantly on the dash, the door buzzer doesn't work anymore when the lights are left on and the interior light does not come on when you open the drivers door. I have cleaned and lubricated the door locks, swapped the door switches (which made no difference) and cleaned the tailgate terminals. I have just put a tester on the drivers side wire that connects to the door switch and its not showing any power going to it. Are the doors fused separately ???
I really don't know what to try next, can anyone help
Old Feb 27, 2012 | 03:04 PM
Paynee's Avatar
Paynee
i think the switches switch a ground rather than +12v so its correct for you to not see any voltage there
Old Feb 27, 2012 | 03:32 PM
Garry Giles
Any idea what the problem could be then. As I said I've swapped the switches so it's not that
Old Nov 8, 2013 | 12:14 AM
Nathan Bromley's Avatar
Nathan Bromley
Originally Posted by Garry Giles
Hi All
Hello I have a ford escort which doesnt make a sound when I leave headlights on with driver door open and no interior lights come on when driver door is open. Did you find a solution to fix this?
Old Nov 8, 2013 | 12:23 AM
SBT83's Avatar
SBT83
Not Crazy, just Unwell
Is it to do with the boot pins and terminals? Sometimes they need a clean up but not sure if it's connected to the Same circuit
Bailes1992
Sep 3, 2015 02:17 PM
rog
30
Aug 29, 2015 11:16 AM
borboyous
Aug 22, 2015 11:17 AM
mrice0107
Aug 21, 2015 07:55 PM
