Diagnostic scanner
Old Feb 15, 2012 | 07:46 AM
ShiftyOldScoob's Avatar
ShiftyOldScoob
Default Diagnostic scanner
Hi folks,
I've been looking into getting myself a decent diagnostic set up. I want something decent from the off so I don't have to buy twice, however I don't want to spend a small fortune so second hand might be an option!
I need it to read and reset fault codes for ABS, air bags etc so what do people recommend ?
Ive looked at snap on but they're all dear unless I went for an older mt2500 unit but I don't really know anything about them!..
Also looked at the blue point micro scan but not sure if it reads abs and air bags etc
Many thanks for your help people!
Old Feb 15, 2012 | 02:27 PM
stevieturbo's Avatar
stevieturbo
C**t
Ask on a proper diagnostics forum like BBA-reman's forum.
Or Ilexa ( although their forum is still down. )
Old Feb 15, 2012 | 04:42 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
i dont have a fancy one that does aircon and brakes, they start getting into big money with those options huh
Old Feb 15, 2012 | 05:12 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
i use bosch kts670, cant imagine using anything else now
Old Feb 15, 2012 | 05:13 PM
Cossie Sean
Blue point one is engine scan only
Old Feb 15, 2012 | 08:42 PM
saph4be's Avatar
saph4be
How good is that one mate? I looking for a good set up?
Old Feb 15, 2012 | 10:15 PM
GVK.'s Avatar
GVK.
All depends what cars you work on, there will very rarely one that does everything.
And if it does it won't be cheap. Can lease some equipment.
I used a Snap on Solus for a few weeks, what a load of shite, wouldn't communicate with half the cars I tried it on.
Old Feb 15, 2012 | 10:19 PM
GVK.'s Avatar
GVK.
Bosch KTS670 Ł4000 on eBay.
http://www.ebay.co.uk/itm/BOSCH-KTS-...9#ht_500wt_949
Or a new one nearly 8k!
http://www.ebay.co.uk/itm/BOSCH-KTS-...item3a6f616433
As Stevieturbo mentions, http://www.bba-reman.com/uk/index.aspx sell and lease diag. tools.
http://www.bba-reman.com/content.asp...gnostics_tools
Also Gendan sell some tools, both hand held and PC based
http://www.gendan.co.uk/index.php
Old Feb 16, 2012 | 12:25 AM
vaughant's Avatar
vaughant
What about the sealey one?
Does it all for about a grand,airbag,abs and fault code,it'll be more than enough for a few years.
I used to use a handheld mac tools one in my garage and it did pretty much all fault codes apart from(ironically as I owned one) a changeover year Corsa.
The snap on one did that but it was Ł5000 compared to my Ł90 unit!!!
Old Feb 16, 2012 | 12:32 AM
vaughant's Avatar
vaughant
Found this link,about Ł1200 all in.
Does loads to be fair plus they offer pretty good service too sealey.
http://toolstoday.co.uk/shop.php?sec...05&tab=details
Old Feb 19, 2012 | 10:18 AM
ShiftyOldScoob
Thanks for the advice so far people!
I'm not looking at spending thousands just yet, but at the same time it would probs save money in the long run....
Been having a look on Ebay and found this http://www.ebay.co.uk/itm/3006667193...84.m1423.l2649
What you recon? is it worth a go at the price or will it be a bag of poo???
Old Feb 19, 2012 | 10:24 AM
stevieturbo
C**t
Until you buy and use any system, you wont know what it wont do. And unlikely the seller is going to tell you !
Old Feb 19, 2012 | 12:19 PM
ShiftyOldScoob
http://www.scantool-direct.co.uk/pro...Reader_amd-801
Anyone used one of these?...seems to do quite alot for the money
Old Feb 19, 2012 | 01:07 PM
DazC's Avatar
DazC
Try a Bosch KTS200 - http://www.bosch-kts200.com/uk/en/index.htm.
http://www.ebay.co.uk/itm/BOSCH-KTS-...0#ht_648wt_932
The KTS670 is top end equipment, KTS340 is mid range and the KTS200 is entry level.
van_dogg_pavvy
Mar 3, 2016 09:30 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Damo V
Technical essay Archives
33
Jun 26, 2006 09:00 AM
dave green
Jul 19, 2005 08:40 PM
Ish
Computers, Consoles and I.T.
Mar 7, 2005 11:25 AM
