intank fuel pumps
Old Feb 14, 2012 | 01:57 PM
cosysop's Avatar
cosysop
Default intank fuel pumps
Has anyone tell me a difference between
bosch pumps
0580254023 (uprated for escos) and 0580254040
Why people uses 023?
Bosch 040 Fuel Pump Specs:
Bosch Part Number: 0580254040
Minimum Current: 12 Volts
Operating Pressure: 94 PSI (6.5 Bar)
Minimum Flow @ Outlet: 80 GPH (300 LPH)
Fuel Pump Location: In Tank
High Temperature Reduction: 8 GPH (30 LPH)
Weight: 930 Grams (2.05 Pounds)
Fuel Pump Connections:
Inlet: Open Base
Outlet: M10 x 1.0
Electrical: Positive M6 / Negative M5
Many thanks
Dmitry
Old Feb 14, 2012 | 05:44 PM
dingla rs's Avatar
dingla rs
023 is good for 450 bhp. standard is not up to the job thats mainly why people change them
Old Feb 14, 2012 | 05:45 PM
cosysop's Avatar
cosysop
why not 040?
Old Feb 14, 2012 | 06:41 PM
dingla rs's Avatar
dingla rs
Originally Posted by cosysop
why not 040?
not heard or seen a 040 mate ,i have a 023 going in my car should be ok for 450
Old Feb 14, 2012 | 06:54 PM
grcossie's Avatar
grcossie
I think 040 is a newer made pump, it was not for sale, when i bought mine 023, you also have 003 who deliver a bit more then 023 if i`m right
Old Feb 14, 2012 | 07:22 PM
mike te's Avatar
mike te
003 is good for up to 550hp
Old Feb 14, 2012 | 07:35 PM
paul16v's Avatar
paul16v
Monte 087
I was always under the impression the 023 flowed more than a 003?
Old Feb 14, 2012 | 10:02 PM
Turbosimpsons's Avatar
Turbosimpsons
What about an 025
Old Feb 15, 2012 | 06:48 PM
mike te's Avatar
mike te
ups
You are right 023 up to 550hp
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
tib2220
Sep 14, 2015 12:33 PM
