any ideas how to get this bastard bolt off?
Feb 13, 2012 | 01:37 PM
Feb 13, 2012 | 01:40 PM
Take the blade off a hacksaw and split the nut, it will take a while but it will be ok. Either that, or get a cold chisel and beat the fucker until it splits or starts to turn.
can you get into it with a welder mate?
or get a ratchet extension with a 90 degree knuckle on it
Feb 13, 2012 | 01:47 PM
Or do it the long way and undo the down pipe to gain access.
Feb 13, 2012 | 02:03 PM
I'd split it with a dremmel cutting wheel
Feb 13, 2012 | 02:04 PM
Quote:
Originally Posted by
Rick
dremel did cross my mind but i havent got one
Feb 13, 2012 | 02:10 PM
the annoying thing is, i bet if you could get a spanner on it it would just probably snap lol.
You could try some penetrating fluid, stick a ring spanner on one end and and use a hammer and chisel/screwdriver to tap the bolt round.
Or try and break the head off with a screwdriver and hammer.
Feb 13, 2012 | 02:15 PM
gas axe no bolt will argue with one!
Feb 13, 2012 | 02:18 PM
get a gas on to it and it will be off in seconds
Feb 13, 2012 | 03:00 PM
can you get the other bolt out? so just that one left, and move the exhaust so that it just snaps the bolt?
Feb 13, 2012 | 03:22 PM
use a multi tool with hacksaw attatchment, easy painless.
Feb 13, 2012 | 03:51 PM
get the gas oot! burn the cunt...
Feb 13, 2012 | 03:52 PM
got it off in the end with a chisel and hammer, awkward place but got there in the end!
Feb 13, 2012 | 03:56 PM
Any blood, or just sweat and tears
Feb 13, 2012 | 04:09 PM
Id whack fuck into it! Failing that just take it all off!
Feb 13, 2012 | 04:22 PM
yep done my knuckle!
What car is that on.What a silly place to have the nut and bolt/stud.
Feb 13, 2012 | 04:27 PM
Glenn.
golf vr6 mk3
Feb 13, 2012 | 04:39 PM
i use these for them type of jobs the belts are real tuff and they fit in tight spots
Feb 13, 2012 | 06:24 PM
gouch1
agreed an air belt sander will grind that nut in seconds
Feb 13, 2012 | 06:57 PM
Really? I've often seen those tools but had no idea what to use one for!
Feb 13, 2012 | 07:08 PM
with one of these:
http://cdn.ruralcentro.net/ImagemPro...grosa-full.jpg
and WD40 on it, then grind the bolt on the side so that the inferior nr spanner is a really tight fit (if it's a good spanner there should be no problem) then hammer the spanner.
Did that for my turbo bolts and worked like a charm.
Feb 13, 2012 | 07:18 PM
gouch1
Cracking bit of kit these are, saved my skin umpteen times!
Feb 13, 2012 | 07:40 PM
drill it with progressively bigger drills it will let go fella
focuspower
Sep 19, 2015 08:27 PM
rogerxr3i
Sep 13, 2015 06:56 PM
rsstav
Sep 7, 2015 04:43 AM
Rizlablue
Sep 6, 2015 09:58 AM
hopper350
Sep 4, 2015 12:53 AM
