General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
2.0l YB 4x4 sapphire
6 long stud block
ported and polished head
BD14 inlet cam std exhaust although he is in talks with someone about a one off profiled cam design?
pocketed pistons
swedish inlet
GT3076 HTA with 44mm tial external wastegate
ARP Rod bolts
lightened flywheel
hydraulic clutch
oppliger big tooth straight cut gearbox?
From: In the unit, building a 450bhp Time Attack Focus!
Originally Posted by J1mbo
What is the difference in the hat to a straight forward gt3076 allowing it to make much more power?
From memory, the compressor wheel is a billet item which moves around 57lb of air at the top as opposed to the 52lb of a standard item.
The nut on the end of the shaft in front of the compressor wheel is modified into a 'bullet' shape, helping the flow into the extended tip of the wheel.
The bearing core is a motorsport metal caged item too on all the 30HTAs.
Gary at APT has had some really good results with them on 2.0 evo engines, here's a graph he sent me a while ago:
And guess what boost it did it at? (Power at the wheels in this one!)
I'd say leave the exhaust cam and get a slightly bigger inlet cam. Power etc depends on boost?
He had 2 bd14s and lacked torque and was bloody laggy on monster T4. Changed to standard exhaust cam and made 40lb ft more. Finished on old spec at 545bhp 500lbft torque
