focus cmax
Old Feb 11, 2012 | 01:13 PM
st phil's Avatar
st phil
Default focus cmax
anybody no any common problems with a focus cmax 2.0 diesel going to look at one tommorow its done 93k 53plate 2004 had a couple of mondeo st diesels before and had problems with egr valves injectors and duelmass flywheel so dont want to be having the same shite again cheers in advance phil.
Old Feb 11, 2012 | 02:13 PM
gouch1's Avatar
gouch1
they are the same engine so have the same problems
Old Feb 11, 2012 | 05:10 PM
James's Avatar
James
Wrong.
cmax is belt driven and mondeo is chain. mondeo is a ford engine and the cmax is a peugeot engine.
No real problens with the cmax though, great cars!
Old Feb 11, 2012 | 05:30 PM
GVK.'s Avatar
GVK.
Fitted a few EGR valves over the years but other than that, good torquey motor!
As said, French engine in these.
Old Feb 11, 2012 | 05:36 PM
xNORMSKIx's Avatar
xNORMSKIx
badass
my dads had a few issues with his central locking but im not sure if this is a common fault.
Old Feb 11, 2012 | 06:29 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
No real problems with ours bar the egr as said,its a 55 plate with 50k miles,went for mot Thursday and failed on rear wheel bearing - shit happens I spose
Good on juice goes well for a diesel when she remembers its got 6 gears lol
Old Feb 11, 2012 | 07:45 PM
russ rs's Avatar
russ rs
Mrs got one only had problems with coil packs on start and ambient lights keep blowing fuses
Old Feb 11, 2012 | 08:07 PM
Steve Escos's Avatar
Steve Escos
Had mine for 6 months, no problems except front bulbs have had to be changed, strange moment the other day when it sort of lost power ( no fault codes?) They are heavy on tyres on the front though.
Old Feb 11, 2012 | 09:33 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
we have had ours just over a year, buts its a 57 plate 1.8 petrol with 17k miles. we have done about 10k in it.
the panoramic glass roof is quite cool, its had a pair of front tyres a few months back, but its just pissed through the mot with no problems.
the only one thing we have noticed is that when pulling away from cold mostly, it seems to loose all power then you rev it a bit more and its fine?
no fault codes etc and it doesnt do it every time.
its been back to ford and they just said to use a better quality fuel. we tried running it on esso for a few tanks and it made no difference so it just fed via the supermarkets still.
doesnt help at all with the diesel engine lol, but they seem an ok car.
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
