a few probs with st3
Hi, got a couple of problems with my st3.
1. when driving I can feel a bit of vibration through the floor, possible rear wheel bearings?
2. the car seems to tramline a lot when driving, just replaced all 4 discs and pads so breaks are not binding. Could this be the wishbone bushes maybe?
3.I had the front wheel bearings done last month and now the calliper on the drivers side catches the edge of the disc unless I put washers behind the moutong bracket, could the bearing be sat out slightly?
Anyone got any ideas so when I take it to the garage I'm not going to get fed a load of crappy about it being this, that, and the other?
Cheers Ian.
Cheers Ian.
