Upcoming Sump pan change(st170)
Right getting my sump pan replaced in the near future as mine has corroded and starting to weep,ive bought a replacement one and got oil,oil filter to get my mate to do the work,just one question do these need a sump gasket or can you use sump sealer?hoping for the latter
Sump pan replaced,fresh oil,oil filter done,replaced the panel filter for a k&n one and removed the resonator,sounds much better now
Just the thermostat to replace on monday now,does it ever end
Another quick update,thermostat replaced,sorted that issue
Also replaced pollen filter,glad i did as the one in there was put upside down and caked in crap,then i put an forte air condition treatment to sort out the funky smell when you turned the A/C off,that is no longer an issue
And got 4 wheel alignment done,so hopefully thats it for a while
155lee
Sep 6, 2016 11:10 AM
