2wd petrol flap gasket
Old Jan 30, 2012 | 01:35 PM
Phil2002's Avatar
Phil2002
Default 2wd petrol flap gasket
as title are these still avalible from ford or what have people used as an alternative.
cheers,
Phil
Old Jan 30, 2012 | 02:20 PM
charlie luciano's Avatar
charlie luciano
Should still be available part no 6144481
Luciano
Old Jan 30, 2012 | 07:56 PM
Phil2002's Avatar
Phil2002
Luciano
sweet nice one thanks mate. +1 rep on way
cheers,
Phil
Old Jan 30, 2012 | 07:59 PM
tosh's Avatar
tosh
I have replaced mine twice over the past few years I think it was about £15 and they always seem to split and crack, the trouble is that they are new old stock but the rubber is still 20 odd years old and not so supple and dont last that long.
Old Jan 30, 2012 | 08:04 PM
Phil2002's Avatar
Phil2002
oh right so a waste of time gettimg a new then, have you found anything else that will do the job?
cheers,
Phil
Old Jan 30, 2012 | 08:34 PM
tosh's Avatar
tosh
I have got some black silicone left over from when I done the kitchen, it's used for sealing joints on Bushboard work tops I don't know what it is made from but you use white spirit rather than water to smooth it of, so I'm hoping it will be petroleum resistant.
That will do for now just to stop water getting in and rotting the inner wing, I will mask off and form a bead over the old rubber seal
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
