Engine swap
Old Jan 29, 2012 | 05:01 PM
craig997's Avatar
craig997
Default Engine swap
Hi guys,
I need a new engine for my mk3 2001 mondeo 1.8 duratec lx. I need it doing quickly so I want to be able to get the first decent engine for the right price. My question is, what engines will fit with the least amount of labour? Obviously the same 1.8 duratec will be easiest, but if I can't find one, can someone tell me which others?
Much appreciated
Old Jan 29, 2012 | 05:04 PM
LukeDaisley's Avatar
LukeDaisley
2.0l will fit aswell. whats up with your old engine? bettom end?
Old Jan 29, 2012 | 05:24 PM
gouch1's Avatar
gouch1
save yourself lots of messing and stick to the 1.8 simple swap over then
Old Jan 29, 2012 | 05:32 PM
craig997's Avatar
craig997
No compression in one of the cylinders. I assume that means complete engine swap?
LukeDaisley
The 2.0l and 1.8 are exactly the same.
Old Jan 29, 2012 | 05:34 PM
craig997's Avatar
craig997
I will if I can find one, but if I can't I want to get next best, and was just checking what that would be. I've seen a comment about post 2003 engines with better manifold or something, would this cause a problem, should I avoid?
Old Jan 29, 2012 | 06:37 PM
LukeDaisley
most 2nd hand engines will come as a bear engine block. the better manifold you are referring to have a improved butterfly flap as they had a tendency to brake and get sucked into the engine.
it may be better/ cheaper to rebuild the engine you have.
Old Jan 29, 2012 | 07:05 PM
craig997's Avatar
craig997
I've been told it won't, they could strip it down and it could still be something that can't be fixed, and that's all additional labour I don't want to pay for.
Old Jan 29, 2012 | 07:19 PM
LukeDaisley
thought you was doing it you self by the way you worded it.
how much of a hurry are you in?
Old Jan 29, 2012 | 08:14 PM
craig997's Avatar
craig997
I need it back on the road within days, well ASAP anyway, I don't have the time to do it myself, even if I knew how and had the tools!
Old Jan 29, 2012 | 08:25 PM
LukeDaisley
Okay, it would be best to buy something vag as those duratec engines a like emo's.
Old Jan 29, 2012 | 08:39 PM
craig997's Avatar
craig997
But that will cost more to fit surely
JoeyBoyden
Jan 4, 2024 02:36 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
track.focus'd
Aug 12, 2015 05:53 PM
vdubo7
Aug 2, 2015 08:17 PM
