General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
I've got -10 on my 3 Door and it fitted a piece of piss, i'm pretty sure -12 would be to big.
Rich
may be its different makes are different sizes?
i got -10 first from torques and it was to tight then tried -12 and was perfect.
the inside diameter of -12 is 17mm and -10 is 14mm.
measure the tank fitting mate, i'm sure its bigger than 14mm
The tank pipe is 15.9mm OD
Inlet on a standard pump is 15mm OD
-10 hose is 14.3mm ID
-12 hose is 17.5mm ID
I just think the -10 is a better fit and plenty big enough for flow.
Rich
where abouts did you measure the tank pipe? theres a raised part to the front of it which it where i struggle. the braided hose doesnt stretch very easy.
i put a adaptor on my pump and a straight hose fitting on the pump side instead of using jubilee clips either side.
