PT Cruiser Diesel...anyone done work on one?
Old Jan 28, 2012 | 07:44 PM
LHD220Turbo's Avatar
LHD220Turbo
Default PT Cruiser Diesel...anyone done work on one?
Just bought a 02 plate Diesel PT cruiser with a clutch problem; anyone done any work on one?
it still does have a clutch pedal but its very spongy at the top and feels normal at the bottom of the pedal, drove it back by starting it in gear. If i dipped the clutch completely it was crawling/ biting so i suspect slave cylinder problem. The slave is internal on these
I "think" the last owner let the fluid get low, so i'm going to try and bleed it first, my idea was to cut the hydraulic line and put a T piece/ bleed nipple in, good idea or bad?
If not, has anyone dropped the gearbox on one? difficult. Or can suggest a proven bleeding procedure
Old Jan 28, 2012 | 07:57 PM
cossiestu's Avatar
cossiestu
Used to sell parts for them, that was a big enough pain in the arse in itself!
On a more useful note, I think there was a "rework" on something to do with the Clutch...? Sorry to be vaige, it was a while ago....!
Old Jan 28, 2012 | 08:07 PM
LHD220Turbo
thanks & no worries ^
doing a bit of digging round on the net, it seems the petrols & diesels had a different system
Old Jan 28, 2012 | 08:16 PM
phil_focus's Avatar
phil_focus
Firstly, if it has a hydraulic clutch there should already be a blead nipple for it.
Secondly, what made you buy one? especially one with a fault? They're right ugly fuckers.
Anyway, hope you get the problem sorted.
Old Jan 28, 2012 | 08:29 PM
LHD220Turbo
couldn't see a bleed nipple!, although to be fair it was only a quick look, will have a closer look tomorrow hopefully
haha, they are marmite, i agree - but its not a keeper, will punt it on once ive sorted it. It was cheap & its diesel
Old Jan 28, 2012 | 08:35 PM
cabriolet's Avatar
cabriolet
on a sour note unless yr lucky any bolt going into the chassis will spin the captive [bloody awful cut open chassis bastard job]
Old Jan 29, 2012 | 10:09 AM
LHD220Turbo
bump..
Old Jan 29, 2012 | 10:15 AM
Russ Payne's Avatar
Russ Payne
will be clutch hydraulics pal
common problem on them and done a fair few sets when i worked for chrysler
Bastard of a job to do!
Russ
Old Jan 29, 2012 | 10:40 AM
BM08's Avatar
BM08
Did it have a fluid leak or something? as every car ive owned for the last 11 years has never used any brake/clutch fluid
Old Jan 29, 2012 | 10:51 AM
LHD220Turbo
Russ
whats the bleeding procedure on the diesels mate?
Old Jan 29, 2012 | 10:53 AM
LHD220Turbo
cant see any fluid between the motor & bellhousing, i suspect the slave is at fault, but wanted to try and bleed it first. Worst case its box out, but there aint alot of room when i looked yesterday!!
JK12
33
Apr 26, 2021 12:09 PM
Rstar_man
143
Jul 20, 2020 11:16 PM
