2wd ecu on 4wd car
Old Jan 25, 2012 | 02:06 PM
motormel's Avatar
motormel
Default 2wd ecu on 4wd car
Hi there
From the experience on here I was wondering if anyone can help. I've got a 4wd shell and gearbox but no engine or engine loom or ecu. Can I run An L6 ecu If I use 2wd tps etc or do I still need the 4wds L8? Also is there any difference between engine looms?
Cos the car is a k reg does that mean lamda sensor etc.
Any help is greatly appreciated.
Thanks
Old Jan 25, 2012 | 05:04 PM
cosy trav's Avatar
cosy trav
L8 (4x4) has lambda sensor and knock sensor on the k reg the engine coolant wire is also on the otherside of the head on the 2wd for the dash gauge . Get a ryan loom and l8 ecu should cost arround Ł 650 .
Old Jan 25, 2012 | 07:29 PM
motormel's Avatar
motormel
Thanks. So the 2wd engine loom and stage 3 L6 won't be any good even if I get a 2wd engine
Old Jan 25, 2012 | 07:51 PM
anglia105e hinson's Avatar
anglia105e hinson
You can do it anyway you want mate.
I have a 3door it's a 4x4 (using full 4x4 late saff engine).
It has a escort cosworth engine loom with an l6 ecu. (the one in 2 parts)
It was running with a 2wd loom and l6 . I stripped back the tape on the loom and extended and redirected certain wires.
Old Jan 25, 2012 | 08:47 PM
motormel's Avatar
motormel
That's a great idea thanks. Just saves some cash and the sourcing of parts. Just a 2wd lump to get. I take it I can use either engine just make sure I get things like the 2wd inlet so can use pf01 tps??
Old Jan 25, 2012 | 09:00 PM
mark r's Avatar
mark r
no pf01 tps now all pfo9 so gotta swap 2 outer wires on loom
Old Jan 25, 2012 | 09:20 PM
motormel's Avatar
motormel
Swap the tps outer wires? Why no pf01? Sorry new to cosworth ownership, done the rs turbo thing and bought things then bought again till got right items, would like to do this once and do it right lol.
Old Jan 25, 2012 | 09:28 PM
martysmartie's Avatar
martysmartie
Not true, if using L1 or L6 you need PF01 TPS, switching the wires on an 09 won't run the engine properly!
You can use the loom still, but extra inputs like knock sensor, O2 sensor (If applicable) will be surplus, CL and knock sensor will not work with 2WD management.
Martin
Old Jan 25, 2012 | 09:41 PM
motormel's Avatar
motormel
Thanks Martin, so 2wd L6 with loom and 2wd sensors ( like pf01 ) will run, just no knock sensor or lamda sensor which is ok.
manuel boeckx
13
Oct 3, 2015 02:29 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Harryh24
Aug 11, 2015 07:48 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
lockie
Jul 31, 2015 10:03 PM
