dry sump for 2.9 cologne
Old Jan 22, 2012 | 11:27 PM
ferguson's Avatar
ferguson
Default dry sump for 2.9 cologne
Hello. I am from USA and currently in the process of building a GRP 2 Capri Clone. I am using a 2.9 12 valve motor with 3 DCNFs and I am trying to find out if there are any dry sump pans or systems available for this motor in Europe. Any info would be appreciated. Thank you very much
Old Jan 23, 2012 | 08:15 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
www.burtonpower.com
nothing available for the Explorer 4.0?
Sean.
Old Jan 23, 2012 | 10:48 PM
ferguson's Avatar
ferguson
Checked Burton. No pans available. 4.0 litre is the same?
Old Jan 23, 2012 | 11:30 PM
lacey's Avatar
lacey
I could do you a kit it you wanted ? , if you want to see a kit or two of mine for other engines I do just to what my kits are like go on burtonpower website and look up O P i dry sump kits and if you like what you see then pm me, cheers
Old Jan 23, 2012 | 11:33 PM
ferguson's Avatar
ferguson
Thanks Lacey. I'll look into that.
Old Jan 24, 2012 | 05:58 AM
Mark V8's Avatar
Mark V8
Might be worth 'phoning or emailing this place.
http://www.chevroletls1.com/ford_cosworth.html
They do block girdles etc for the V6 and may be able to help ?
regards
Mark
Old Jan 24, 2012 | 08:25 AM
PAUL S's Avatar
PAUL S
The prosport race cars used that engine and no doubt had dry sumps, so they should be out there. A wanted ad on racecarsdirect.com might help
Old Jan 24, 2012 | 09:45 AM
ferguson's Avatar
ferguson
Thanks Mark and Paul both. Good info
Old Jan 24, 2012 | 10:04 AM
PAUL S's Avatar
PAUL S
these guys built the race versions so should be able to help you out
http://mdrengines.co.uk/
jessie_rs
62
Aug 6, 2019 09:27 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Iain Mac
Sep 30, 2015 09:39 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
youngben
Sep 27, 2015 09:37 PM
