UNDERSEAL
Old Jan 22, 2012 | 09:54 PM
D16PJM's Avatar
D16PJM
Default UNDERSEAL
What is the best method to get 40 year old underseal off of a car and what to replace it with.
Thanks Pete
Old Jan 22, 2012 | 10:09 PM
beaver rs 88's Avatar
beaver rs 88
in the garage
Lots of patience and elbow grease fella took me 3 weeks to get all mine off with wire wheel heat gun and scraper. Absolute nightmare but worth it when it all off and clean.
Old Jan 22, 2012 | 10:37 PM
fordrs2005's Avatar
fordrs2005
A hot pressure washer / steam cleaner
That's what I used for my escort , just basically pealed it of
Old Jan 22, 2012 | 10:55 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
Did the same on my Escos last week, worked nicely till the steamer part broke on the pressure washer! It's like a half stripped patchwork quilt at the mo
The cleaned bits do look super clean though
Old Jan 22, 2012 | 11:01 PM
3FRD's Avatar
3FRD
Whatever you do don't use Waxoil, in my experience it creates water traps and hides/creates more rust than it prevents. I've started using POR15 it's a frost product and is good stuff!
Old Jan 23, 2012 | 09:07 AM
JamesH's Avatar
JamesH
Mine took weeks of a couple of hours here and there at weekends, with a wire woll on a drill/angle grinder! Horrible job, but soooooo worth it once it's done!!
Old Jan 23, 2012 | 12:37 PM
D16PJM's Avatar
D16PJM
so there isn't really an easy option unless i can get a steam cleaner/jetwash and lots of hard work, whats best to put back on it, the reason i have to strip it is that it has started cracking and will now hold water but can't complain as its been on there since new and never welded.
Old Jan 23, 2012 | 01:23 PM
JamesH's Avatar
JamesH
It's worth it just for peace of mind mate, and it looks awesome painted properly!!
I'd use stonechip then 2k and top coat!
IainRS1700T
Sep 25, 2015 06:44 AM
smitsturbo
Nov 7, 2006 02:10 PM
shane
Aug 16, 2006 08:44 PM
Nick500
Apr 22, 2005 02:26 PM
Moondust_crust
Oct 29, 2003 09:15 AM
