Setting up Efi CVH - XR2i
Old Jan 22, 2012 | 11:26 AM
paulsheerin's Avatar
paulsheerin
Default Setting up Efi CVH - XR2i
Hi guys,
Done a bit of searching but not had much luck.
The CVH in my XR2i seems to be running very rich. There's a strong smell of petrol from the exhaust fumes and she just generally seems to be running rough at low RPM (even for a CVH). She also seems to be quite hard on fuel at the moment as well.
Anybody know how to set up the fuelling on one of these?
Thanks
Old Jan 22, 2012 | 07:32 PM
Brendan's Avatar
Brendan
struggling with reality
have you tried to adust the POT on the back of the engine bay its on the same plate as the EDIS and the MAP sensor! This could be s STARTING point for you. be carefull it can make things worse. So put a small mrk on it with tipex so you can put it back to where you started!
JK12
33
Apr 26, 2021 12:09 PM
TPM961
Jan 15, 2018 10:50 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
bigryrs
Sep 7, 2015 06:45 PM
