a little zetec question please
Jan 22, 2012 | 10:16 AM
is it the sensor on top of the thermostat housing that gives the signal to the ecu
the gti is killing fuel at an alarming rate at the mo
60miles on 20 quid lol
and i take it it's the lower one that gives the reading on the dash
Jan 22, 2012 | 10:35 AM
Can't remember but unplug one when it's running. If the dash goes, you know which is which.
Matt
Jan 22, 2012 | 11:05 AM
I thought it was the black square plug under the thermostat housing that the ecu uses
Jan 22, 2012 | 11:12 AM
thats it throw a spanner in the works lol
this is what i need to know
Jan 22, 2012 | 11:13 AM
both sensors are for temp readings the top one is for the gauge and the bottom one is for the ecu
Jan 22, 2012 | 04:18 PM
the small 1 on the bottom is dash signal, 1 on top is ecu, thats how i got mine running any how,
Jan 22, 2012 | 04:21 PM
Quote:
Originally Posted by
dlatch
thats wrong mate , top one for ecu and the bottom one is for the gauge on the dash
cheers paul
Jan 22, 2012 | 04:25 PM
gonna go to my local ford dealers tomorrow nd get 2 new sensors as i dont think the car is coming out of choke
very flat when given full throttle
Jan 22, 2012 | 04:27 PM
Jan 22, 2012 | 04:28 PM
martysmartie
Not a MAF issue?
Martin
maybe
will try the cheap things first
Jan 22, 2012 | 04:29 PM
Sounds like a MAF problem to me too.
Jan 22, 2012 | 04:34 PM
is there anyway to check / test the maf
Neil Clark
21
Oct 1, 2015 07:02 PM
Fiddy
21
Sep 29, 2015 06:10 PM
focuspower
Sep 20, 2015 03:51 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
