ford transit fault
Old Jan 19, 2012 | 04:33 PM
Turbosimpsons's Avatar
Turbosimpsons
Default ford transit fault
a mate of mine has a 57 plate fwd tranny which keeps loosing power, it doesn't do it all the time, then suddenly it's back to normal. anyone any ideas. thanks in advance
Old Jan 19, 2012 | 04:38 PM
little bram's Avatar
little bram
Try a pcm update mate and carry out pump lean. has it got any dtcs? and how dose it tick over?
Old Jan 19, 2012 | 05:10 PM
DangerousBryan's Avatar
DangerousBryan
try a fuel filter as well if it hasn't had one for a while. ditto the pcm update. maybe a sticking egr valve as well
Old Jan 19, 2012 | 05:23 PM
Turbosimpsons
a what! whats a pump lean, has it got any what. it ticks over slightly higher about 200-300 rpm higher
Old Jan 19, 2012 | 06:06 PM
little bram
haha or dear ok mate well best thing to do is find someone with a computer to plug in and going from there really. try the fuel filter they do cause alot of problems but from there youl need a computer really.
ps put a G-ford filter on mate they work best.
Old Jan 19, 2012 | 07:35 PM
I would try a fuel filter.Dont forget to fill the new filter up with fuel or the engine will be a twat to start.
Old Jan 19, 2012 | 07:41 PM
shauns's Avatar
shauns
nobody knows me..
i have a 56 plate, always had trannys and this is the worst bastard ever, had similar turned out ta be fuel pressure regulator relay thingy bastard thing
Old Jan 19, 2012 | 08:17 PM
Turbosimpsons
Funnily its just had a non gen filter on it, could that cause it.
Old Jan 19, 2012 | 08:33 PM
jameswrx's Avatar
jameswrx
As far as I know the transit fuel filters are patented so I'd imagine genuine and non genuine are probably from the same manufacturer. Saying that the Ford logo'd ones do seem to fit better/easier.
van_dogg_pavvy
Mar 3, 2016 09:30 AM
borboyous
Aug 22, 2015 11:17 AM
Bailes1992
Aug 16, 2015 07:14 PM
Mark RS
14
Aug 11, 2015 11:45 AM
