Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
N/A cossie in a Mk2
Old Jan 19, 2012 | 09:20 AM
porterste's Avatar
porterste
Default N/A cossie in a Mk2
I am fitting a N/A cossie into my mk2 escort rally car I have finally got round to restoring. I have dummy fitted a block to a T5 gearbox and mounted it on pinto world cup engine mounts. The problem I have is that the gearstick hole is to close to the handbrake. has anyone else fitted a T5 box to a Mk2? Is this where it should be or have I got the engine mounts wrong and the whole lot needs to come forward. Any help would be appreciated
Old Jan 28, 2012 | 07:52 PM
Joe Grp4 Escort's Avatar
Joe Grp4 Escort
When you put a type 9 or a t5 box in a mk2 on crossmember mounts you normally have to shorten the handbrake handle
Old Jan 28, 2012 | 08:49 PM
mk1yb's Avatar
mk1yb
Think the T5 is slightly longer than the type 9. You could possibly solve the problem by fitting a quickshift to shorten the throw of the gearstick and possibly bendinging the lever foward slightly so it doesn't hit the handbrake in 2nd and 4th gears.
Old Jan 29, 2012 | 08:47 AM
essy's Avatar
essy
For the Cosworth gearbox I moved the handbrake mounting hole backwards an inch or so.
Old Jan 30, 2012 | 09:20 AM
rsmark86's Avatar
rsmark86
As above a fabricated the mounting points on the hand brake to move it back slightly
And the hole where the gear lever came through had to be moved back I was on a type 9 tho
You do relise the t5 is a big heavy box and you would be better off with a straight cut type 9
Old Jan 30, 2012 | 01:23 PM
porterste's Avatar
porterste
Thanks for your input guys we have fabricated a gearbox mount using a type 9 mounting and extended it and bolted through the floorpan to h duty steel plate with bolts made captive on it so it just needs the nuts taking off from underneath to get the box out.
We reckon the type 9 and T5 gearboxes are about the same length, the problem arose because it previously had a rocket box in it. As part of the restoration we fabricated a large gearbox tunnel so we had no problems with clearance. The propshaft had to be shortened by 55mm.
The box and prop are now in place we have gone for an hydraulic handbrake next to the gear lever as when the seat is in if the handbrake lever is moved further back I will not be able to give it a good tug. We may locate original handbrake further back or shorten the lever on it to retain a cable handbrake as per MSA regulations
Old Jan 30, 2012 | 06:48 PM
Hoogi's Avatar
Hoogi
I just installed a Hydraulic Handbrake futher back to solve that issue...........
Old Jan 31, 2012 | 07:10 PM
Oddified's Avatar
Oddified
Whilst not fitted into an escort, i had the same issue with a type 9 box/cosworth engine and the handbrake. I got round the problem by cutting off the top section of the gearbox tail housing, shortened the selector rod and moved the gearstick mount forward by 4" and re-welding it. Works perfectly and has done for years now.
It's another option.
Ian
Old Feb 12, 2012 | 08:53 PM
mk2 escort boy's Avatar
mk2 escort boy
Or you could use a tvr t5 gearbox gear stick is further forward by 2 inches got one in my mk2
Old Feb 12, 2012 | 08:58 PM
graham c's Avatar
graham c
mine woz fine in my first mk1
Old Feb 22, 2012 | 06:18 PM
J40davies's Avatar
J40davies
some inspiration for you!!
Old Feb 22, 2012 | 06:35 PM
TommyB's Avatar
TommyB
Boosted 122 cu in
Sweet engine bay, trumpets look mean.
Old Feb 22, 2012 | 08:12 PM
graham c's Avatar
graham c
how much power dose one of these shove out
Old Feb 22, 2012 | 08:47 PM
J40davies's Avatar
J40davies
Thanks!
Mine's a genuine 2ltr putting out 230bhp at the flywheel. Not mega power tbh! Only running a standard cossie crank, could get more if I went for a steel crank and revised head porting n cam combo! BUT...the wallet isn't too keen on that idea! Lol. Millington gets about 280 out of his 2ltrs...show off! Lol.
Old Mar 6, 2012 | 05:56 PM
porterste's Avatar
porterste
Nice looking engine bay mate. We have slowed down on build a bit has we have had to rebuild the Escort Cossie rally car engine and that means taking all the front end off to get it out.
Hoping to get the Mk2 finished in a month or so just rewiring at the moment
Kiran1600E
11
Oct 2, 2015 11:35 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Sp3no
Sep 27, 2015 07:23 PM
