engine pre heaters
Old Jan 17, 2012 | 02:28 PM
boaby's Avatar
boaby
Miester
Default engine pre heaters
who has 1? i was thinking of getting 1 know that winter is over
are they any good or just a waste of your hard-earned?
Old Jan 17, 2012 | 03:39 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
depends on the car. They all do the same and bring the coolant and eventually the block and oil upto about 80 Degrees. Some heat interior for you too.
in wear terms, if you do a lot of short or town journeys then it probably makes sense as your engine is mostly warmed up straight away, and the 10p a cycle to heat up probably saves more than that in fuel that would be wasted in the inefficient cold run/warm up period.
Old Jan 17, 2012 | 03:45 PM
boaby's Avatar
boaby
Miester
obviously you'll get different Wattage (or whatever they are measured in) but how long do you turn it on before using the car? 5/15/25 minutes?
Old Jan 17, 2012 | 03:56 PM
DrewSS's Avatar
DrewSS
warrens spot on there as usual.
I had a kenlowe pre heater on my discovery it came on everytime you turned the key on and switched off when the thermostat reached 80ish. No idea on price as it was fitted to it when i brought the motor. But, i highly recommend them as there so useful in clearing the screen too in seconds.
Old Jan 17, 2012 | 04:03 PM
Brendan's Avatar
Brendan
struggling with reality
I use a radient patio heater at 1.3 KW to heat my sump on a cvh engine for about 20 mins if I havent used the car for a while in winter, very cheap very efective!
Old Jan 17, 2012 | 04:04 PM
Psycho Warren
Carbon Crazy
how long depends on the one you buy
there are different ones, electric ones and diesel fuelled ones. the diesel ones ideal for vans/off roaders who dont want to be tied to a plug.
for home use the electric ones are fine. They say its about 30-40 mins if you include interior. They have a simple plug you hide in a grill/hole somewhere so no complex wiring each day.
Easy way to use it is to set it up on a timer plug in the house, that way no need to remember in the mornings.
Old Jan 17, 2012 | 05:23 PM
boaby's Avatar
boaby
Miester
i dont have a drive though
dont fancy having a length of cable laying across the pavement incase some scally helps himself to my leccy!
Old Jan 17, 2012 | 10:39 PM
Alg1k's Avatar
Alg1k
I have a webasto one and its remote control with a fob or by phoning it
When my dreaded alarm goes off i turn it on
about 20 min before i go to work
It also heats the interior
Its good at work as i have to leave the car quite away away so i can phone it,
best thing on the car
Old Jan 17, 2012 | 10:41 PM
.Ross.'s Avatar
.Ross.
What, Do you mean a Block heater?
Old Jan 17, 2012 | 10:45 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
Burtons/Kenlowe do them,
Audi been fitting them as standard option since way back when in the 90`s IIRC, if not earlier
Old Jan 18, 2012 | 07:05 AM
boaby's Avatar
boaby
Miester
yah
Kyle Langford
27
Aug 5, 2019 07:54 PM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
K42L
Aug 28, 2015 01:23 PM
borboyous
Aug 22, 2015 11:17 AM
Old ford
Jul 31, 2015 06:50 AM
