Turbo Damber - Fitting Problem
Old Jan 17, 2012 | 12:04 PM
Alan G's Avatar
Alan G
Default Turbo Damber - Fitting Problem
Hi all,
Went about fitting a Bailey turbo damper to my Mk1 Escort YB project yesterday! It's running a T3 Turbo that was rebuilt by CRTurbos bolted to a 2wd exhaust manifold! When I bolt the two washers onto the turbo hanging bracket I seem to be running out of thread for the upper rose joint to even reach the bottom rose joint.....
Here are a few pics to show the problem a bit better!
Has anybody come accross this problem before? Is it just a case of getting a longer threaded rose joint?
Old Jan 17, 2012 | 04:18 PM
BRAMMER's Avatar
BRAMMER
The hanger i had was fitted with a bearing for an 8mm bolt - you would have to make sure what size threaded part
http://www.ebay.co.uk/itm/Self-lubricating-8mm-Rotary-Ball-Rod-End-Bearing-New-/260926958728?pt=LH_DefaultDomain_15&hash=item3cc07 56c88
Old Jan 17, 2012 | 04:31 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
That is a turbo Hanger NOT Damper.
They resonate around 3500-4000rpm
Steve
Old Jan 18, 2012 | 02:05 PM
R4N SS's Avatar
R4N SS
Steve
mine didnt resonate on my 3dr at all mate - and gonna be getting one for the saph soon too
Old Jan 18, 2012 | 03:12 PM
Rsmat's Avatar
Rsmat
Must just be on a 4i...
Old Jan 18, 2012 | 03:20 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
just go on ebay and get a longer rose joint plus as said its not a damper as it has no movement in it to dampen its a turbo hanger to take some on the weight off the manifold / manifold studs
Old Jan 18, 2012 | 03:22 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I have heard them do it on other 3drs and taxis's so not just the 4i
Steve
Old Jan 18, 2012 | 03:52 PM
Rsmat's Avatar
Rsmat
Steve
Love ya buddy....
Old Jan 18, 2012 | 06:44 PM
Alan G's Avatar
Alan G
Thanks for the help lads!!
Sorry for the confusion.... seems to have started an on-going feud!
Will go on the bay and go in search for a longer rose joint for my Hanger!
Old Jan 19, 2012 | 02:32 AM
Rob Virgo's Avatar
Rob Virgo
I'll measure mine when I get into garage al, yours is most likely for a t35
Old Jan 23, 2012 | 05:55 PM
bigluke200's Avatar
bigluke200
I'm with the tall guy on this one.. I've had two of those bailey hangers on two different cars and they both made a horrible racket at certain revs
Dr. Ickxs
Aug 15, 2015 11:34 AM
marky_g
Aug 15, 2015 10:43 AM
