Can someone that actually knows clear this up for me?(front diff removal)
Old Jan 17, 2012 | 09:21 AM
rog's Avatar
rog
Default Can someone that actually knows clear this up for me?(front diff removal)
When removing the front diff in a cossie, do you have to drain the engine oil also?
Although I have put my car together I have never removed the diff alone, but from what I remember, where the shaft goes through the sump is a sealed section, so it wont be in communication with the diff and the oil wont be released when I remove the diff.
Would just like to check as I have seen various comments on here saying that the oil will come out too??? I dont believe thats true.
Post 9
https://passionford.com/forum/ford-s...ow-tricky.html
Old Jan 17, 2012 | 02:31 PM
tomanycosworths's Avatar
tomanycosworths
You don't need to drain the engine oil it will be separate, the shaft runs in a tube so doesn't come in contact with engine oil. Also the diff oil is contained in the diff as the output shafts have seals.
Old Jan 17, 2012 | 02:34 PM
rog's Avatar
rog
Thanks, thats what I thought! I hate this place sometimes, but it can be very helpful also!
Chas
Sep 21, 2015 08:57 PM
borboyous
Aug 22, 2015 11:17 AM
C2 MAK
Aug 20, 2015 09:46 PM
mattman1234
15
Aug 14, 2015 10:05 PM
track.focus'd
Aug 12, 2015 05:53 PM
