I assume your talking about the fronts? I didnt think the 4wd came with 4pots. Just 2 pots. may be wrong but even if they are 4 pots they are different
Surly the 4wd would of been better with 4 pot brakes?
Yes but 4WD were not 2WD running gear, so oviously money isn't going to be spent if they can otherwise cut back.
As said 4x4 doesn't have 4 pots, it's simple single pot sliding design all round, front discs are different sizes at the front as well, and are a different type at the rear.
Martin
Could you put 2wd calipers on a 4wd? I bet i have to make a stupid bracket that i could never make lol.
I understand would the money cut backs and all but 4 pot is going to be better so really ford should of put them on and just charged customers.
