Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Ford 1999 focus 1.8 fuel pump removal ...
Old Jan 15, 2012 | 02:43 PM
matt86_wd2's Avatar
matt86_wd2
Default Ford 1999 focus 1.8 fuel pump removal ...
Hello all , i have been trying to remove the fuel pump from my fuel tank this afternoon but with no luck ... i have got access to the pump unit and the locking ring off .Its just when you pull the top part of the body out you have 2 pipes that conect to the pump body and sender unit . Thats the bit i can not get out ... is there 2 tabs i push or tun it a certain amount or what ... ? I didnt want to give it a hard tug in case i broke the pump ..
I know its different depending on the years ...
Oh and as well i broke the return pipe coupler but have got a new one on its way . Where does the other end attach to ?
Cheers , matt
Old Jan 15, 2012 | 05:48 PM
nevsrevs's Avatar
nevsrevs
you need to twist the swirl pot anti clock wise, then the whole white pot comes out, then two torque screws hold it in place, it will be stiff?
Old Jan 15, 2012 | 06:23 PM
matt86_wd2's Avatar
matt86_wd2
where would these torx screws be located on the top of the swirl pot , or on the base as on the bottom on the tank like holding brackets down ?
Old Jan 15, 2012 | 08:12 PM
nevsrevs's Avatar
nevsrevs
no mate where the two fuel pipes meet on top of the pump, two black screws on the top, twist the whole lot out first, float and all, comes out in one, have a look at my build thread, {focused on track zetec turbo} and see the picks, if its the same
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
kosienutter
31
Aug 22, 2015 09:55 AM
taylora1409
Aug 12, 2015 12:06 PM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
