swirl pot
Hi guys I am looking for a little bit of help I am fitting a fuel swirl pot into my fiesta cosworth the tank is in the boot and I am going to put the pot under the car but I am not sure if I will still need a lift pump or not
Most people use a low pressure pump to fill the swirl pot, then an external high pressure pump to supply the engine from the swirl pot.
There are a few more pipes to attach before you get it all up and running, but I think that may answer your question
Thanks for you help mate i was just not very sure if it would be ok to fit it with out the low pressure pump as it will be under the tank and could be gravity feed cheers
depending on what power your running will depend on pump size . i ran a atl bac tank in my last escort with a 2.5lt swirl pot, i fed the pot with a 044, then i fed the rail with 2 x 044 pumps.
thanks steven
thanks steven
