Throttle bodies on cvh
Old Jan 14, 2012 | 11:44 AM
rsmark86's Avatar
rsmark86
Default Throttle bodies on cvh
As the title
Does anyone have any info on what's needed to fit throttle bodies on a cvh
The engine in question is as follows
1640cc
Fully worked crank
Ultralite steel flywheel
Fardon steel rods
Accrulite forged pistons
Decked block and skimmed head
Pocketed pistons
Uprated oil pump
Arps throughout
Burton stage 3 big valve head
( head is going to wpe for some extra work)
Newman phase 3 cam reprofiled for 5500rpm too 9000rpm
Newman solid lifters and puma race engines double valve springs
I know I need a dcoe inlet and jenvey 45s ect but what would I need to pick up sensors/ coil pack ect to make run
Looking at megasquirt or omex
Old Jan 14, 2012 | 11:46 AM
rsmark86's Avatar
rsmark86
The old owner had twin 45 dcoes with megajolt and had 180+ bhp from it
Old Jan 14, 2012 | 12:27 PM
Brendan's Avatar
Brendan
struggling with reality
have fun with that!
Old Jan 14, 2012 | 12:56 PM
rsmark86's Avatar
rsmark86
i take it its not easy then......
i was thinking of just fitting the 45s and megajolt but then throttle bodies will be alot nicer
Old Jan 14, 2012 | 01:08 PM
zippyobrien's Avatar
zippyobrien
Drill the block and run a crank sensor and efi flywheel.
Then squirt and a set of bodies. You going dry sump for that many revs ?
Old Jan 14, 2012 | 05:12 PM
gus's Avatar
gus
dry sump will be custom as no one does one
Old Jan 14, 2012 | 05:44 PM
rsmark86's Avatar
rsmark86
its got a fully baffled sump on it but he never ran one......
i have been thinking about fitting a new cam thats not so wild, ive had alook and newman do one the the power band is 4000-8000rpm?
i didnt want to use a efi flywheel as ive got a skeleton style steel one with it
Old Jan 15, 2012 | 06:20 PM
Dayle's Avatar
Dayle
Here's one I built on throttle bodies. Yet to have it to the rolling road yet.
They are bike TB's though.
Old Jan 15, 2012 | 06:29 PM
Marc D's Avatar
Marc D
think you may have to change to efi flywheel for the sensor. if it was me id just fit a pair of 45s. would love to have a cvh this spec in my xr2. would go like stink and must sound awesome at 8000rpm. be fantastic round a track as long as chassis and brakes are well specced
Old Jan 16, 2012 | 09:49 AM
rsmark86's Avatar
rsmark86
What throttle bodies are they
Are you using trigger wheel or efi flywheel
Old Jan 16, 2012 | 09:50 AM
rsmark86's Avatar
rsmark86
It's going in my weekend toy escort for road use, in looking at megasquirt with trigger wheel ect
Old Jan 16, 2012 | 11:37 AM
Marc D's Avatar
Marc D
ah right fair doos. like you said above probs best with a slightly milder cam and yer id go for throttle bodies as well if it was a road car
Old Jan 16, 2012 | 11:42 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
you can always fit a camshaft sensor and use that, doesnt have to have a flywheel sensor
bodies definately a better idea than carbs, carbs belong on historics and thats about it!
Old Jan 16, 2012 | 03:18 PM
rsmark86's Avatar
rsmark86
Could anyone advise me what I will need to collect the bits
Really want bodies, and will bike bodies flow aswel as jenveys?
Old Jan 16, 2012 | 09:20 PM
Dayle's Avatar
Dayle
They are gaxr throttle bodies 38mm. It's a xr2i block with crank sensor. People have had good results with bike tbs.
That engine has lightened and balanced bottom end
Arp rod bolts
1300 pistons to raise compression
1640cc ish
stage 3 big valve head with stainless race valves
Kent cvh27 rallym 3500-7500 rpm with double springs and mechanical lifters and adjustable vernier
Then the throttle bodies. Haven't got a clue what it will go like but should be ok.
Old Jan 16, 2012 | 10:00 PM
rsmark86's Avatar
rsmark86
Wicked sounds good and should go well,
I'm looking at fitting jenvry 45mm bodies but need to find out how much megasquirt will be
Old Jan 17, 2012 | 06:53 AM
Dayle's Avatar
Dayle
To be honest mate unless you can map yourself I wouldn't go with megasquirt. I would look around and see what your local mapper prefers to map and knows how to map it.
I use DTA now as megasquirt isn't that cheap any more, not like it used to be in the early 00's, it also uses or did do cheap poor quality components that had no place within a ecu, Dorn't get me wrong the megasquirt can do well but I struggled to get a couple of well reccomended rolling roads to map it as they wouldn't touch it as they said it was a DIY ecu and i could understand where they were coming from. Dodgy solder joint lets go because its been soldered together in someones bedroom and it melts a engine.
Old Jan 17, 2012 | 07:14 AM
luke19790_3's Avatar
luke19790_3
got my megasquirt from efiextra. Around 360 to buy, no soldering needed.
Old Jan 17, 2012 | 09:12 AM
Chip's Avatar
Chip
I agree that if you dont want to map it yourself then find a mapper first and use something they are happy with.
Old Jan 17, 2012 | 09:23 AM
zippyobrien
45 mm bodies are a bit big really aswell,
would have thought 40s would give more tourque
Old Jan 17, 2012 | 09:26 AM
Chip's Avatar
Chip
By the sounds of his cam, I doubt he'll have much torque anyway TBH unless high up in the rev range, and the 45s will be ok there.
Old Jan 17, 2012 | 10:47 AM
zippyobrien
i got a set of arp main crank bolts that might be of some use to you mark
Old Jan 17, 2012 | 03:25 PM
rsmark86's Avatar
rsmark86
cheers guys ive had alook around and as i said to the missus ive got no rush because ive got a mk2 frs to use anyway.
ive been looking at options for ecus, and its between dta,omex and ms.
i was looking at 45mm jenveys because i know where to get them for a good price, and knowing me i will end up with a zetec later lol
the ms for Ł360 is cheap though and would that come with loom kit and just need a trigger set up, because if thats all it will need i will just do that
Old Jan 17, 2012 | 03:28 PM
rsmark86's Avatar
rsmark86
i think its got them but will check with the engine builder.... its going to wayne at w-p-e on friday,
also im looking at changing the cam for a less aggressive item that revs 4000-8000rpm
but we will see as ive been advised to maybe look at fitting twin 45s and omex 200 and look into things like lsd, brakes, and oil cooler ect
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
