Clutch Issues
Old Jan 12, 2012 | 05:19 PM
Jasoncmor's Avatar
Jasoncmor
Default Clutch Issues
Hi all.
This was my first post when I joined, but looks like I posted in the wrong section, oops.
Anyway,
I need a little bit of advice on my clutch.
Its a mk4 fiesta with the 1.25 zetec engine.
My clutch is very high, but its not slipping at all, tested by using a higher gear at low speed and accelerating.
I've noticed that the first 2-3 inches you press the clutch pedal down that it feels spongy before any pressue is resistance is behind it.
Also, when my car is idling, I can hear a whirling sort of sound inside the car, but it dissapears when I press the clutch down.
And also, on the odd occasion, when changing down gears, it can be a little tricky to get it iinto first gear, doesnt happen often, but it happens, It's very stiff but can be pushed in if pushed a little firmer.
Any idea what the problems could be?
Thanks in advanced.
Jason
I know the noise is the clutch bearings now.
I think there may be a leak somewhere, where I am unsure.
Could that right?
Could a leak let air into the system and make the clutch feel soft/spongy like I am experiencing?
Cheers, Jason
Old Jan 12, 2012 | 05:35 PM
LHD220Turbo's Avatar
LHD220Turbo
normally a high biting point is the sign of a worn clutch, but it may not slip.
the noise you can hear is probably the release bearing, but you wont know for sure until you take the box out - it could be that the relase bearing is weeping, which might explain the pedal feel if air is in the system.
does the clutch pedal ever go to thew floor and wont come back of its own accord? have you noticed any fluid on the floor where you park it?
i've never done a clutch on this car so cannot help any more
Old Jan 12, 2012 | 05:40 PM
saph4be's Avatar
saph4be
All the symptoms off a knackered pressure plate! Or iirc the slave cylinder/ release bearing is weeping and contaminated clutch!
Old Jan 12, 2012 | 05:45 PM
gouch1's Avatar
gouch1
sound like your clutch pressure plate is no good i'd replace with clutch kit and bearing
Old Jan 12, 2012 | 05:50 PM
saph4be's Avatar
saph4be
Is there a parrot in here?
Old Jan 12, 2012 | 05:51 PM
Jasoncmor's Avatar
Jasoncmor
Thanks for your replies.
No, the pedal always comes back up when released. And I haven't noticed any fluid on the ground either. But about 6 months ago, I noticed a very small amount of fluid underneath, on the n/s of the engine, on a rubber bit which looks sort of like the bendy part of a straw.
Cheers.
Old Jan 12, 2012 | 05:52 PM
gouch1's Avatar
gouch1
is there a parrot in here
i was writing it out a same time whats wrong
Old Jan 12, 2012 | 06:10 PM
Jasoncmor's Avatar
Jasoncmor
So, just to clear things up, I'd need a new clutch, pressure plate and slave cylinder? Just those 3 things?
Do you need to drop the engine out to change the clutch?
Thanks, Jason
Old Jan 12, 2012 | 06:12 PM
saph4be's Avatar
saph4be
Thanks, Jason
No need to drop engine mate on Thames and yes you need all three should come as a complete kit but check first as sometimes release bearing is separate!
Old Jan 12, 2012 | 06:20 PM
Jasoncmor's Avatar
Jasoncmor
Thank you for clearing that up, and thanks for your help
Old Jan 15, 2012 | 10:32 PM
Jasoncmor's Avatar
Jasoncmor
One last thing, do I need any special tools like a clutch center tool, or anything else? I have pretty much every other basic tool.
Cheers.
Old Jan 16, 2012 | 06:31 AM
saph4be's Avatar
saph4be
Cheers.
No mate just standard tools a clutch alignment tool can help but I have all ways done it by eye.
Old Jul 30, 2012 | 05:29 PM
Jasoncmor's Avatar
Jasoncmor
So, finally got round to sorting my car out.
Half the front end of the car is taken apart and it currently sat in the car ready to be refitted after I have replaced the clutch and other parts.
The gearbox was easy enough to remove, not as heavy as i'd expected, I was able to carry it into the shed, out the way, bit awkward but how am I gonna get it back onto the engine after i've done the clutch? Is it quite easy? I'm a little worried I wont be able to do it.
I had my dad on hand to help hold it while I lowered it on the jack, and he should be able to help with refitting, just don't know how its going to go :/
Also, I noticed with my cv joints, if I move them there is a very slight clicking sort of sound, only very slight though. Are these going to be safe enough to use for now? Hopefully will only have the car for another year before being scrapped or whatever.
One last thing, what grade transmission fluid should I use?
(and man it smells bad!)
Cheers, Jason
Old Jul 30, 2012 | 06:08 PM
saph4be's Avatar
saph4be
Sure it's just ep 90 gearbox oil but your larval motirfactors can check.
As for fitting box make sure clutch is centre and then just use your strength, I normally get them on my chest lol but if there's 2 off you it should be easy mate
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
