Some lovely bits for you Cosworth guys ;) UPDATED 16/01
How about some of these sexy bits?
Bosch Grey Injectors - £150
Regulator with fittings and lines - SOLD
Monster Grp A K&N Filter with Trumpet - £80
Compomotive MO 7x17 ET40 Wheels and Like New Eagle F1 GSD3 Tyres
The wheels are in great condition apart from 2 very light scuffs which have been touched in and are a real struggle to notice which are shown in the 2nd and 3rd picture. There is a little bit of wear inside the wheels from stones going around inside, but this is almost impossible to see once mounted and hidden behind the brake disc.
£600
Genuine Weber 3 Bar MAP sensor - £50 posted
AP BRAKES - 4 pot 330x28mm brakes complete with brackets and bolts, built by Reyland. Have covered 10,000 miles only. Plenty of life left on them, discs are not lipped and the Ferrodo DS2500 pads have about 10mm of material on. All in all very good condition and awesome brakes.
£1000
GT2871RS Turbo, built into a T3 flange with a V- Band quick release exhaust end. This turbo cost me well over £1200 and has covered only 3000 miles. Selling with the exhaust manifold which has been ceramic coated and selling with the actuator.
No play at all and comes with a boss for an EGT Sensor - £800 or £750 to you if you don't want the manifold.
Defi BF Gauges
These are the 1st generation BF gauges which are sort after and better looking than the ones Defi make now. They come with the gauge, wiring and sensor, no cups or feet. These can be bought for next to nothing through a Defi dealer should you require them.
Water Temp - £120
Oil Temp - £120
Boost - £120
Oil Pressure - £160
Fuel Pressure - £160
EGT - £160
Control ECU mk2 - £50
Warning light - £20
I also have most of my RS Turbo, probably more bits that will go on a Cosworth. Have a look here - https://passionford.com/forum/ford-r...-for-sale.html
Open to sensible offers
Thanks very much.
£600
£1000
Defi BF Gauges
Water Temp - £120
Oil Temp - £120
Boost - £120
Oil Pressure - £160
EGT - £160
Warning light - £20
Thanks very much.
Well, they were for my RST, but the wheels came from a 2 wheel drive 3dr originally and Martin used the offset to make the bells. So I would think that they would go on another 2 wheel drive car. If not, I'm sure Martin can make up the correct brackets to make them universal.
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
