2.o zetec in a mk1 sierra
Old Jan 11, 2012 | 08:42 AM
kevhp171's Avatar
kevhp171
Default 2.o zetec in a mk1 sierra
as above can someone please write a list of parts that is needed to do this conversion and how easy a fit is it what does it roughly cost
cheers in advance
Old Jan 11, 2012 | 08:46 PM
anglia105e hinson's Avatar
anglia105e hinson
alright mate someone has asked this before so ive copied stuff i said before.
One of my mates is carrying out a 2.0 Zetec in a Dutch mk2 3door at the moment, you basically need to go down the same route as putting one in a mk1/2 escort or any thing else retro.
If you don't mind spending a little bit of money use the parts that 'retro ford' supply they do everything to convert to rwd. But with the sierra because it's basically the same as a 1800cvh you can use the standard crossmemeber and use the cvh engine mounts. This will keep all the engine and gearbox in the same place making it quiet straight forward.
Me and my old man also carried out this out on his cortina 1600e except we done it all for bout Ł300 !! With custom parts and different bits and pieces
Hope this helps mate
Get hold of a DOHC 2.0 8v sierra or Granada starter. They are very short and are the right bolt pattern. I'm pretty sure the zetec one is too big. Have a look on eBay at brand new cheap starters I bought one for my Cossie beginning of last year and still going strong even though there cheapies.
f you do a quick search on turbosport there is a section devoted to zetec installations and pretty sure I've seen wiring diagrams. If you don't have any luck I'll try to find mine.
Originally Posted by anglia105e hinson
Here's the pics lads. Shows both cvh 1800mounts on a zetec.
The passenger side can only take 2 bolts but he is gonna brace it across from another spare hole.
Old Jan 11, 2012 | 08:49 PM
anglia105e hinson
http://img.photobucket.com/albums/v6...2/085591ca.jpg
http://img.photobucket.com/albums/v6...2/8e596ae5.jpg
http://img.photobucket.com/albums/v6...2/25758920.jpg
http://img.photobucket.com/albums/v6...2/5bcf729e.jpg
http://img.photobucket.com/albums/v6...2/1213b4ed.jpg
Old Jan 11, 2012 | 11:35 PM
robrs2's Avatar
robrs2
The above photos
Old Jan 12, 2012 | 07:49 AM
kevhp171's Avatar
kevhp171
cheers for that it seems simple enough so i better start looking for all the bits now
Old Jan 12, 2012 | 06:17 PM
anglia105e hinson
Cheers robrs2 don't know Why it didn't work first time.
Old Jan 12, 2012 | 09:26 PM
robrs2's Avatar
robrs2
Just the tags on them.
Though of putting a zetec turbo into my 3 door. Its a lot lighter than the BOB V6 thats in.
JK12
33
Apr 26, 2021 12:09 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
Adam Graham
Sep 6, 2015 06:04 AM
Ben26
Sep 3, 2015 07:55 PM
