Zetec convertion on mk1 sierra.
Old Aug 17, 2011 | 09:44 PM
wulliesxr4i's Avatar
wulliesxr4i
GIT-R-DONE
Default Zetec convertion on mk1 sierra.
Hey guys just wonderin if any u guys could help me with a list of things ad need to b able to get a standard zetec lump in a mk1 1.6l sierra and get it running.
Any help would b great.
Old Aug 17, 2011 | 10:03 PM
anglia105e hinson's Avatar
anglia105e hinson
One of my mates is carrying out a 2.0 Zetec in a Dutch mk2 3door at the moment, you basically need to go down the same route as putting one in a mk1/2 escort or any thing else retro.
If you don't mind spending a little bit of money use the parts that 'retro ford' supply they do everything to convert to rwd. But with the sierra because it's basically the same as a 1800cvh you can use the standard crossmemeber and use the cvh engine mounts. This will keep all the engine and gearbox in the same place making it quiet straight forward.
Me and my old man also carried out this out on his cortina 1600e except we done it all for bout Ł300 !! With custom parts and different bits and pieces
Hope this helps mate
Old Aug 17, 2011 | 10:37 PM
wulliesxr4i
GIT-R-DONE
Thanks mate. So sierra Cvh engine mounts bolt straight on to the zetec then yeah? So do u need to change the sump to past the cross member? Is it easyer to run them on carbs or fuel injection? How do u wire everything up? A want to use the car everyday so need it to b cheap nd reliable to run really. also u say bout the gearbox is this just the Cvh 5speed? Would I need to change the flywheel/clutch?
Old Aug 18, 2011 | 03:35 PM
anglia105e hinson
Yes engine mounts bolt straight on, but on passenger side only 2 out of the 3 bolts will go in.
Sump, my mate has bought the retro ford sump which was a direct and no hassle fit.
Carbs or injection well its up to you really my mate is going using a bike carb kit which was bout Ł800 for everything, but that is gonna be for track purely.
Or on the otherhand me and my old man fitted all the original ecu and injection from a mondeo with 'non pats'. It isn't hard at all only a few wires to power it all and for clocks.
But if your not confident with wiring it may prove a bit difficult.
It is alot cheaper and will run sweet as a nut like a mOndeo.
It's up to you really mate.
Gearbox you van use any type 9 5speed except for the v6 one as this has a longer input shaft. Also make sure the starter is on the exhaust side of the bellhousing.
With the clutch there's a few ways to do it. Get a 1800 zetec flywheel and redrill to suit a pinto clutch and pressure plate.
Or
Like we have use the full zetec mondeo clutch system( actually bigger diameter than pinto) and modify the clutch fork or the hole it goes through to get full engagement. Use a threaded adjustable clutch cable. It works really well on our cortina
Old Aug 18, 2011 | 04:34 PM
wulliesxr4i
GIT-R-DONE
Thank u mate very useful info there. Do u hav any idea on how much the sump was?
Would b very interested in the wiring to so I could contain the standard ecu nd just run it like it should hav been in the donner car.
I have a gearbox and engine mounts that will do the job, if u use the zetec flywheel am guessin u use the zetec starter aswell to match.
Old Aug 18, 2011 | 10:31 PM
anglia105e hinson
No worries mate. Not too sure on price for sump but have a look on there website or a magazine.
For the starter motor you need to. Get hold of a DOHC 2.0 8v sierra or Granada starter. They are very short and are the right bolt pattern. I'm pretty sure the zetec one is too big. Have a look on eBay at brand new cheap starters I bought one for my Cossie beginning of last year and still going strong even though there cheapies.
Old Aug 18, 2011 | 10:34 PM
anglia105e hinson
If you do a quick search on turbosport there is a section devoted to zetec installations and pretty sure I've seen wiring diagrams. If you don't have any luck I'll try to find mine.
Old Aug 19, 2011 | 08:22 AM
wulliesxr4i
GIT-R-DONE
Thanks mate from wot u hav been sayin it dont sound to hard to do really the only thing that's really got me wondering how to do it is the wiring. But ma old man nd brother-inlaw are good at the wiring so will just need to find out how to do that part lol
Old Aug 21, 2011 | 06:38 PM
haadee's Avatar
haadee
could you also do a topic in project section with updates?
as im planning to do same conversion
Old Aug 21, 2011 | 06:46 PM
boy-racer-1's Avatar
boy-racer-1
i cant remember his name on here but he had the blue 3 door with the built up zetec turbo engine, he told me the cvh engine mounts dont line up when it comes to puting the engine in the sierra as i was previously told they fit and well him having done the conversion and saying they dont fit i took his word for it and from then on didnt bother with the zetec conversion as i cant make custom engine mounts
Old Sep 7, 2011 | 11:00 PM
anglia105e hinson
The cvh sierra engine mounts do fit 100%
I'll take photos of them tomorrow night and post them up.
Old Sep 8, 2011 | 02:07 PM
boy-racer-1
cheers will be good to see some proof of these engine mounts fitted and holding the engine in a sierra
Old Sep 8, 2011 | 02:11 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
The person that built the zetec turbo was fidgey. perhaps he still has the mounts as the cars been broken up now
CosworthGuy
3dr Cosworth owner
The person that built the zetec turbo was fudgey. perhaps he still has the mounts as the cars been broken up now
Old Sep 8, 2011 | 04:48 PM
anglia105e hinson
Sorry lads I'll get photos tonight it was raining last nite and couldn't be bothered to go out.
Old Sep 8, 2011 | 04:55 PM
boy-racer-1
lol yea this is the message i got from him a while ago when i was thinking of puting a zetec into my sierra
fudgey: hello mate, i was told that 1.8 cvh mounts fitted, but did they fuck!
well, the didnt fit mine anyway.
Old Sep 8, 2011 | 05:35 PM
anglia105e hinson
Lol that's weird then. I really cant see how it didn't work.
The only thing I can think of is I know that there are two types of silvertop zetec blocks. One has starter at the front of engine and one has one at the back. And when you bolt up a type 9 gearbox one of the holes is missing at what would be the back of the block( in a fiesta or escort)
There are some unused drilled and tapped holes in both engines and these are what the mouts bolt to. So it could be the fact that these holes arent drilled and tapped in his block which is why the mounts didn't fit.
Old Sep 8, 2011 | 06:50 PM
anglia105e hinson
Old Sep 8, 2011 | 06:52 PM
anglia105e hinson
Here's the pics lads. Shows both cvh 1800mounts on a zetec.
The passenger side can only take 2 bolts but he is gonna brace it across from another spare hole.
SMILER258
36
Sep 28, 2015 09:04 AM
Tank Mike
Sep 26, 2015 08:07 AM
focuspower
Sep 20, 2015 03:51 AM
focuspower
Sep 19, 2015 08:27 PM
