timing up cam trigger - please help
Old Jan 11, 2012 | 07:32 AM
Heitmann's Avatar
Heitmann
Default timing up cam trigger - please help
Hi
I've got my hands on a cam trigger kit, and have just handed over my cam to be machined.
I have 2 questions I hope to get help to
I've read this guide by Richie
https://passionford.com/forum/techni...r-to-a-yb.html
but about timing it up i would like to hear if it is just a matter of timing up everything and making sure the phase sensor in the distributor is on the mark, and then installing the modified cam, with the trigger pointing up to the sensor
and after installing the cam, i can remove the distributor.
or is is simply matter of looking at the timing mark on the inlet cam pulley, and just turning the cam trigger lobe 90 degrees clockwise?
Also how do I check clearance in the best way, between the trigger and the sensor?
many thanks
Old Jan 11, 2012 | 07:53 AM
saph4be's Avatar
saph4be
I know you can't just remove distributor as it runs the oil pump! You need a proper blanking plate for it
Old Jan 11, 2012 | 08:06 AM
GARETH T's Avatar
GARETH T
has your cam trigger got one (wrc style) or 2 lobes (standard ecu style) ?
Old Jan 11, 2012 | 09:22 AM
Heitmann's Avatar
Heitmann
thanks - I know
Its got 2 lobes
Old Jan 11, 2012 | 09:41 PM
GARETH T's Avatar
GARETH T
its been a while since ive timed a cossie,, but i think it right in saying, that the sensor should be sensing the first lobe at TDC
Old Mar 19, 2012 | 08:19 AM
Heitmann's Avatar
Heitmann
Well I got it timed up and it works perfect
RUBY123
Oct 22, 2023 12:04 PM
Danielbetty
Oct 3, 2015 06:01 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
taylora1409
Aug 12, 2015 12:06 PM
