T34 Exhaust Housing
Old Jan 10, 2012 | 02:49 PM
Brian's Avatar
Brian
Default T34 Exhaust Housing
Does anyone have any pictures of a exhaust housing fitted to a T34 turbo?To
I have just tried to fit my turbo to my Area Six manifold and i can't get the bolts for the exhaust to face downwards
Here's what i have
Here's the problem
Need the housing to sit other way so studs point down so can fit down pipe
Is there another housing available for this turbo? If so what one?I
Brian
Old Jan 10, 2012 | 08:00 PM
dave cos4x4's Avatar
dave cos4x4
can you not use a cosworth housing be facing the bulkhead then.
Old Jan 10, 2012 | 08:04 PM
saph cos rob's Avatar
saph cos rob
swindon rsoc
the only way i can see you doing that is like above use the cosworth 3 bolt houing or similar, you couldnt have it facing down else it'l hit the gearbox?
Old Jan 10, 2012 | 09:49 PM
105epwr's Avatar
105epwr
You need a t3 "v" band adaptor there on ebay
Old Jan 10, 2012 | 09:55 PM
105epwr's Avatar
105epwr
EBay number
Should sort your prob
Old Jan 11, 2012 | 07:00 PM
Brian's Avatar
Brian
From what cosworth mate? 4wd, 2wd or escort?
Brian
Old Jan 11, 2012 | 07:01 PM
Brian's Avatar
Brian
Originally Posted by 105epwr
390340442874
EBay number
Thanks mate will have a look
Brian
Old Jan 11, 2012 | 07:19 PM
mk1turboestate's Avatar
mk1turboestate
i cut turned and rewelded mine but im not sure how long it will last
Old Jan 11, 2012 | 07:22 PM
Brian's Avatar
Brian
Any pictures mate
Brian
Old Jan 11, 2012 | 07:31 PM
plynchy's Avatar
plynchy
Can't you rotate it 180 degrees so the inlet is over the gearbox, exhaust flange looks like it will then point down between the gearbox and rad?
Old Jan 11, 2012 | 07:35 PM
mk1turboestate
here you go pal
engines been running quite a few times now with the exhaust un supported and no problems so far, most people on here said it wont last but i thought id give it a go
Old Jan 11, 2012 | 08:21 PM
dave cos4x4
Any Cosworth one will do but depending on what size housing you want to use, probably the smaller .48 housing might be better as this is a better response as its smaller than a .63 housing.
As for fitting it, you need to take the cast housing complenty off so the core is showing and bolt the Cosworth housing on and spin it round to where you want it and line it up then tighten it all up.
May be better calling a tuning company to get advice off them.
Old Jan 11, 2012 | 08:33 PM
Brian's Avatar
Brian
here you go pal
Thanks mate looks alright
Brian
Old Jan 11, 2012 | 08:35 PM
Brian's Avatar
Brian
Cheers for the info mate where would i get one from?
Brian
Cosnada
Jan 7, 2016 05:30 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Russ Payne
Sep 25, 2015 08:29 PM
