Fitting .63 housing on a cr t38
Hopeing some body could help.
Just gone to fit a .63 housing on my cr turbos t38 but it doesn't fit over the turbine blades. I am guessing it has to be machined out internally?
Thanks
Thanks
t4 turbine as far as i know, had the same trouble as i was going to fit a smaller housing to my t04b, realised it wouldn't fit by a mile so stuck with 0.63 which is much better as spec went through the roof in the end.
you may be able to get it machined though.
Oct 9, 2015 07:38 PM
