Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
mk1 Focus brake issue
Old Jan 8, 2012 | 05:49 PM
Camel Fiddler's Avatar
Camel Fiddler
Resident Camel Stalker
Default mk1 Focus brake issue
I went to do my front brakes today as the pads are getting low. Managed the nearside no issues but when I've come to do the drivers side, the caliper screw has been rounded off
My plan is to use an oversized socket (9mm or so) hammered in to the screw to remove it. Or use an easy out screw extractor. But does anyone have another suggestion, or know how much the screws are at Ford?
Also I think I need to bleed my brakes so anyone know the nipple size? I think it's 8mm but when I had a quick go it was stuck solid
Cheers lads
Old Jan 9, 2012 | 01:18 AM
Camel Fiddler
Anyone?
Old Jan 15, 2012 | 09:04 PM
martysmartie's Avatar
martysmartie
The correct size is a 7MM allen, as you say I have found with allens tapping them up a size can help, so many people overtighten these most likely why yours has rounded! I think 8MM would be about right maybe try some WD40 first? So long as you don't sheer it off!
Martin
Old Jan 15, 2012 | 11:04 PM
Camel Fiddler
It had to be hammered out with a hammer and 8mm socket as it was actually a perfect circular shape inside. Once it was removed it was fine. Beware though as the securing screws are £34.60 a pair from ford!!!!
Scrapyard ftw!!!!!
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
saph in dorset
Aug 14, 2015 10:10 AM
track.focus'd
Aug 12, 2015 05:53 PM
Red_bull
Aug 9, 2015 08:34 AM
