which cam belt
Old Jan 8, 2012 | 05:09 PM
stu170's Avatar
stu170
Default which cam belt
Time to get the timing belt changed. which to go for? car is a focus st 170. any other parts i should be changing at the same time?
cheers folks
Old Jan 8, 2012 | 05:59 PM
DangerousBryan's Avatar
DangerousBryan
GET a ford one.and get someone that knows what there doing to do it.. these are not the same as the normal 1.8/2.0's
Old Jan 8, 2012 | 06:50 PM
botters's Avatar
botters
competant bodger
get a gates timing belt kit you dont need the extra exspense of a ford kit because gates make genuine belts for 99% of manufacturers anyway easy enough belt to do if you have the locking kit and are competant with tools, do not attempt if not tho
Old Jan 8, 2012 | 06:51 PM
Gates belts arw good too.I would be changing the adjuster and the idler.
Old Jan 8, 2012 | 06:56 PM
Robs Frst's Avatar
Robs Frst
May be worth changing the Water pump.
Old Jan 8, 2012 | 07:42 PM
studabear's Avatar
studabear
afaik the water pump is driven from the aux belt
Old Jan 8, 2012 | 07:55 PM
botters's Avatar
botters
competant bodger
correct no need to change at same time as the cambelt
Old Jan 9, 2012 | 04:28 AM
Might as well change the aux belt whilst thats off.
Old Jan 9, 2012 | 05:56 AM
tat2cliff's Avatar
tat2cliff
Used the gates belts every time, same as fords but cheaper
Old Jan 9, 2012 | 06:02 AM
tat2cliff's Avatar
tat2cliff
A gates belt every time mate, my sons rst is mental and he swares by em and i have also used em many times in the past
Old Jan 9, 2012 | 09:03 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i think it has been said enough, but once more, Gates belt kit.
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
