HELP gauges playing up!
Old Dec 20, 2011 | 11:24 AM
Carlos-Titx's Avatar
Carlos-Titx
Default HELP gauges playing up!
As per usual in the mornings I start the car, let it run for several minutes then head off to work. It wasn't till I got to the motorway that I noticed the oil gauges were the same as when cold, temperature very low and pressure high (5bar). Pulled over and when the car idled the pressure dropped to the correct point on the gauge as when cold but the car was warm?
Any one else heard of this or know why?
Thanks.
Old Dec 20, 2011 | 11:25 AM
Carlos-Titx
The oil temp gauge stayed the same all the way to work.
Old Dec 21, 2011 | 04:46 PM
DJMST's Avatar
DJMST
SHELL GARAGE VIP
Pull the KAM fuse resets it or plug in your DS handset and read the DTC's,it wont show any codes but once you clear the "no" codes it works again no problem
Old Dec 21, 2011 | 04:51 PM
Carlos-Titx
Cheers. Guys on another forum said the same.
The thing started working again but will remember next time not to crap my pants and panic lol
Old Dec 21, 2011 | 05:18 PM
RichieST's Avatar
RichieST
Supposed to be quite a common fault, don't worry about it. Starting it up and let it tick over from cold is doing the most damage, just get in and drive it carefully until it's warm.
Old Dec 21, 2011 | 08:46 PM
DJMST's Avatar
DJMST
SHELL GARAGE VIP
It's something to do with the connection down at the front of the symposer pipe,but for the life of me can't remember what the name of the bit is,wots ur username on focusstoc
Old Dec 21, 2011 | 08:55 PM
Carlos-Titx
DJMST same as my user name here mate.
Richie, Just jump in and drive off boost then? Why is that? Old wives tale to let things warm before driving then?
Old Dec 21, 2011 | 09:21 PM
GVK.'s Avatar
GVK.
Could try a map sensor, had a similar fault with an ST a couple of years ago, was cured by fitting new map sensor.
http://j-w-racing.co.uk/product.php/...e62e2301197e64
Those gauges don't actually read directly from individual temp/map sensors, their readings are calculated via other sensors/data in the ECU and the information goes to the gauges via CAN.
location of map sensor http://www.team-focus-st.net/TeamST/...echnik/map.jpg
Old Dec 21, 2011 | 09:24 PM
Carlos-Titx
That clears up why i was boggled as to why guys on STOC mentioned MAP and MAF sonsors!!!!!
Nice one.
Old Dec 21, 2011 | 09:39 PM
RichieST's Avatar
RichieST
Yes, the engine produces very little heat when idling. The longer an engine is cold for, the longer the oil is thick and not lubricating properly and an engine is running out of it's tolerances for longer, thus causing more engine wear. Also the plugs will get sooted up from the overly rich mixture. Best thing is to jump in and drive from cold without putting too much load on the engine until it's warmed up.
Old Dec 21, 2011 | 10:23 PM
Carlos-Titx
Cheers for the info Rich, appreciated mate.
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
