Saff rear tyre sizes on 18"?
Old Dec 8, 2011 | 07:01 PM
WongRS's Avatar
WongRS
Default Saff rear tyre sizes on 18"?
What do you RWD boys run on the back with 18"?
I have a feeling my 205-40's aren't going to handle the new engine too well, so was thinking of upgrading, maybe to 225-35?
What you running, and with or without arch work?
Old Dec 8, 2011 | 07:06 PM
KSA-Cossie's Avatar
KSA-Cossie
Pretty sure you'll get a 235 on dan
Old Dec 8, 2011 | 07:09 PM
BigErn's Avatar
BigErn
I think Helens are 225/30 18 on the rear of her 4x4.....
Old Dec 8, 2011 | 07:14 PM
J1mbo's Avatar
J1mbo
B1mbo
225/30 ern? Not 225/35
Id like to get a 235 on back of mine, have rolled arches, but running coil overs and 6 degree beam and don't want them to catch!
Old Dec 8, 2011 | 10:33 PM
BigErn's Avatar
BigErn
I cant remember if its 30 or 35 mate.... 30 was more prominent in my mind for some reason. Might be 35 profile now you mention it as I think the front is 215 35 and the rears are wider but same profile, I only know this cos I asked her what size tyre she needed for the rear of her car and she took the size from a front and when I went to fit it realised the dozy moo has wider on the rears . I may be getting confused with my M5 as that had 35 profile front and 30 rear. If she's online she, might, be able to tell you
Old Dec 9, 2011 | 05:37 PM
WongRS's Avatar
WongRS
Thanks Chaps, 225-35-18 seems a tad limited for choice, budget crap, new kumho pattern (not a fan) or Mich pilot sports, but they are Ł145 a piece to me, f*%k that.
Old Dec 9, 2011 | 05:59 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
I have 235/40/18 on rear of mine Jimbo for several years now. Arches need to be properly cut back not just rolled & you must run standard ride height none of this lowering & destroying the handling shite. Have also run 225/40/19 on the road these will rub up in the arches on bumps.
Old Dec 9, 2011 | 06:03 PM
WongRS's Avatar
WongRS
Sounds a nightmare, if 235's do for you, i am sure a 225 will be ok for me!
Who's quote is that in your sig, Rod? made me laugh.
Old Dec 11, 2011 | 06:15 PM
Damocos's Avatar
Damocos
Im running 225 35 18 Toyo's on the rear of my saff with 8x18" Mo's with an ET39 offset and i have no rubbing Not done any arch mods either
Old Dec 11, 2011 | 06:54 PM
J1mbo's Avatar
J1mbo
B1mbo
Damo, is your car low? And are you on coil overs?
Old Dec 17, 2011 | 09:15 PM
Damocos's Avatar
Damocos
Yeah i'd say its low, on AVO 2wd -30mm springs and Koni's. Does sit nice
I will get some close up pics tomorrow as im at the garage.
Old Dec 17, 2011 | 10:15 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
The quote is Tom Ford on 5th gear to Tiff Needall after Mark Shead had just run 206mph in the wet.
Old Dec 18, 2011 | 10:11 AM
WongRS's Avatar
WongRS
Ah, knew i recognized it, thanks.
Old Dec 18, 2011 | 10:20 AM
AJC's Avatar
AJC
I run 215/35
Old Dec 18, 2011 | 10:57 AM
WongRS's Avatar
WongRS
I cant stand 215/35, the ride is horrendous i found on mine, and they cracked wheels, profile is just a touch too low.
225/35 seems to be the winner i think.
Old Dec 18, 2011 | 01:59 PM
lukeytheduke's Avatar
lukeytheduke
i run 225 35 18s on the rear with goodyear eagle f1 asymetrics and handling and grip is amazing. Well as good as it can be for a rwd car lol
3drRich
Sep 13, 2015 07:32 PM
Marc sierra
12
Aug 30, 2015 10:38 AM
borboyous
Aug 22, 2015 11:17 AM
IAN RS2k
Aug 18, 2015 07:51 PM
