compression ratio of standard 1.8 zetec
Old Feb 20, 2005 | 07:40 PM
jonesymk2's Avatar
jonesymk2
Default compression ratio of standard 1.8 zetec
as above does anybody know and would it be the
same with a cvh head on
Old Feb 20, 2005 | 07:54 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
10:1 as std if i recall correctly, and about 8.3:1 with a CVH head on mate......both figures from the top of my head as I havent seen the calcs in ages!
Old Feb 20, 2005 | 08:05 PM
jonesymk2's Avatar
jonesymk2
with the cvh head on would that compression ratio be safe to run
with a turbo and if so what pressure could i run safely
Old Feb 21, 2005 | 02:16 PM
jonesymk2's Avatar
jonesymk2
can anybody help me with this please,i can probably get hold of
a 1.8 zetec engine out of a written off mondeo at work
Old Feb 21, 2005 | 05:38 PM
PhilM's Avatar
PhilM
BTTT for RichM, he will be able to help!
Id say personally, that with a cvh head, the 1.8 zetec bottom end should give ~ 8.3:1, and IMO that should be fine to run as is, upto say 1bar boost.
I know MattSab and Huw (mungus), both ran these at some stage, no idea what they use now! I believe Matt reported he was having det problems at one stage, whether or not this was directly CR related or not i dont know.
Hopefully someone like Rich can offer some advice!.
Old Feb 22, 2005 | 07:48 AM
jonesymk2's Avatar
jonesymk2
ok cheers for that,if i do change the engine i would hav only been
using it with about 10psi of boost so would that be safe
Porplus12
Sep 10, 2015 07:20 PM
Dubs44
Aug 21, 2015 02:42 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
taylora1409
Aug 12, 2015 12:06 PM
gingerturbo
Aug 11, 2015 09:44 PM
