Any hgv fitters on here
Old Nov 23, 2011 | 09:03 PM
Evorich's Avatar
Evorich
Default Any hgv fitters on here
Help required on ghanging twin plate clutch on renault premuim, done the job just carnt get the clutch to clear so can engage gears, if you pump the clutch you can get a gear but bites at the floor, have bleed clutch and adjusted the rod on the slave clyinder but still no avail. Plz help ta rich
Old Nov 23, 2011 | 09:32 PM
.Ross.'s Avatar
.Ross.
Did you put the intermediate plate in the right way?
Old Nov 23, 2011 | 09:40 PM
Evorich's Avatar
Evorich
the whole clutch kit came preassembled with four holding bolts so just bolted it up, but after the second time i pulled the gearbox out i pulled it all apart and its all been bolted up right, going to try a genuine renault clutch tomorrow
Old Nov 23, 2011 | 10:03 PM
t-man's Avatar
t-man
how old is the premium? i work for at renault trucks
Old Nov 23, 2011 | 10:04 PM
STUCOS's Avatar
STUCOS
Try back bleeding the clutch ie from the slave cylinder back,oh and it,s technician not fitter lol
cheeRS stu
Old Nov 24, 2011 | 05:28 PM
Evorich's Avatar
Evorich
Problem solved . Put a genuine Renault sach clutch in bolted all back up and set slave adjustment to where it was originally and it's perfect. Thanks for the help. Lessoned learnt never get a cheap and nasty clutch lol.
Old Nov 24, 2011 | 05:31 PM
kev 3dr's Avatar
kev 3dr
Volvo's are usually the ones that are a nightmare with those spacers !!!
Old Nov 24, 2011 | 07:15 PM
STUCOS's Avatar
STUCOS
Bet the genine clutch wasnt that much dearer ither,plus carries a 12mths road side warranty threw europe
cheeRS stu
danneth
Oct 25, 2006 10:25 AM
*Bri.4.b.Cos*
Oct 6, 2006 08:25 AM
Benn 304R
Oct 2, 2006 07:20 PM
Stavros
12
Nov 24, 2005 11:34 PM
kevsrs
Nov 16, 2004 07:21 PM
