2.5 turbo transit question
Old Nov 22, 2011 | 08:36 AM
Trist's Avatar
Trist
Default 2.5 turbo transit question
Will a 2.5 n / a transit take an exhaust manifold and turbo to make it a turbo or is compression ratio to different?
Old Nov 22, 2011 | 05:47 PM
Trist's Avatar
Trist
Up for the evening people.
Old Nov 22, 2011 | 06:15 PM
Ima Racing's Avatar
Ima Racing
...hi i think you can do it as i had a 2.5 n/a with a turbo/intercooler conversion. I doubt the compression was altered...the receipt was from Lancaster Diesels it cost 2k in 2005, maybe worth a call.
Old Nov 22, 2011 | 06:20 PM
dug112y's Avatar
dug112y
passionford pro
its different management too with fly by wire throttle....called 'epic' IIRC
Old Nov 22, 2011 | 06:42 PM
Trist's Avatar
Trist
management is not needed and the electronic fuel pump will be canged for mechanical
basically we have a fishing boat at work thats come in with a marine converted transit engine. it runs different exhaust manifold that is water cooled with a much larger turbo plus water cooled air cooler all cooled by sea water via a pump mounted on the idler pulley
the engine is in need of work so the cheapest option is another 2.5 transit engine and put all the marine conversion bits on.
only thing is the turbo one I bought for him is in worse condition and the only other they have is a non turbo. do i put the head from the turbo on the non and use that or is it more different than that. or do I need to bother and put the stuff including turbo on the non??
Old Nov 22, 2011 | 09:07 PM
ZVH,RST's Avatar
ZVH,RST
just use the complete 2.5 di engine and bolt the turbo and manifolds on it,it will be ok,loads of people have done it,just bolt the turbo on standard 2.5dis and they run fine.the bosch 145,or 146 pump is the best
Old Nov 22, 2011 | 09:13 PM
Trist's Avatar
Trist
cool, so cmpressions are the same? if it were mine I would chuck it all on and have a go but ths is a paying customer so i want to make sure its ok and will run ok.
Old Nov 22, 2011 | 10:52 PM
DazC's Avatar
DazC
Turbo and non turbo where basically the same engine. It'll be fine.
Old Nov 23, 2011 | 08:51 AM
Trist's Avatar
Trist
Compression ratio for turbo is 18.3:1
Non turbo is 19:1
Old Nov 23, 2011 | 07:43 PM
ZVH,RST's Avatar
ZVH,RST
Smile
make sure you use the 100ps turbo injectors,and turn the pump fueling up,but you can get bigger 130ps marine injectors,
Matt Baxter
Sep 16, 2015 08:30 PM
Adam-M
Aug 27, 2015 08:55 AM
SteveyDee
Aug 25, 2015 07:48 PM
borboyous
Aug 22, 2015 11:17 AM
A.t.p
Aug 15, 2015 11:37 AM
