hart inlet plenum
Old Nov 21, 2011 | 05:51 PM
flannigan's Avatar
flannigan
Default hart inlet plenum
can somebody please sell me one of these to suit a eeciv escort cos throttle body !!!
Old Nov 21, 2011 | 05:55 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
i have one on order at the mo they have to be made with a bigger flange plus there is a problem with the throttle cable bracket thats why ive been waiting for just over a month for mine but i should have it this week as he was meant to be picking up the bracket on saturday
Old Nov 21, 2011 | 06:00 PM
flannigan's Avatar
flannigan
who or where did you order youre one from mate ?
Old Nov 21, 2011 | 06:03 PM
ajamesc's Avatar
ajamesc
direct from the guy that makes them joe from bluesprint 01621744881 if i remember right you have to order it with a 4 inch flange he will know anyway he has been having trouble with mine over the cable bracket lol
Old Nov 21, 2011 | 06:08 PM
flannigan's Avatar
flannigan
i take it you are also using the same t/b setup ?
Old Nov 21, 2011 | 06:13 PM
ajamesc's Avatar
ajamesc
yes the small turbo escort one as at the mo i have the small turbo plenum cover was going to just use a 2wd throttle body but was told to stick with the escort one
Old Nov 21, 2011 | 06:17 PM
flannigan's Avatar
flannigan
yeah its bigger so can only be better imo ill give him a bell tomorrow then am i rite in saying they are £500 ?
Old Nov 21, 2011 | 06:22 PM
ajamesc's Avatar
ajamesc
i payed 495 with a fitting kit it o ringed and the cable braket
Old Nov 21, 2011 | 06:24 PM
flannigan's Avatar
flannigan
thank you for youre help
Old Nov 21, 2011 | 07:03 PM
J1mbo's Avatar
J1mbo
B1mbo
What power are you aiming for?
Old Nov 21, 2011 | 07:43 PM
flannigan's Avatar
flannigan
its 500bhp already i had a complete s/t inlet on it with t/b and when i spoke to tony @ turbosystems he advised that if i changed to a better flowing plenum it would aid throttle response and mid range pickup i could use a std throttle body to get the power i have but as i already have the larger throttle body it seems silly not to use it
Old Nov 21, 2011 | 08:41 PM
J1mbo's Avatar
J1mbo
B1mbo
Fair enough, was going to say if your using standard don't bother as there is no restriction there, but if already on the bigger pipes fair enough
Old Nov 22, 2011 | 09:48 AM
Markb_s1's Avatar
Markb_s1
Check you out Dan!!! going for throttle response/mid range now!
You're obviously getting faaar too into this track day action!
Old Nov 22, 2011 | 12:06 PM
flannigan's Avatar
flannigan
Hee hee hee yeah I want it to be the best it can be getting a sequential 6 speed box too
Old Nov 22, 2011 | 12:56 PM
Markb_s1's Avatar
Markb_s1
nice!
have to catch up soon mate!
Old Nov 22, 2011 | 05:06 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
My EECIV TB has the same bolt spacing as a 2wd TB. Its just the holes are bigger on the EECIV.
Steve
Old Nov 22, 2011 | 05:19 PM
flannigan's Avatar
flannigan
ordered the plenum today cant wait till next week to collect it
Old Nov 22, 2011 | 06:56 PM
ajamesc's Avatar
ajamesc
Steve
when i asked my tunner about getting one he said i need to order it with the bigger 4inch flange (i think) for the small turbo throttle body plus yes the bolt holes are different
Old Nov 22, 2011 | 06:59 PM
ajamesc's Avatar
ajamesc
did you order it with the throttle cable bracket and if so did he say you would have that in a week
Old Nov 22, 2011 | 07:08 PM
Mark Shead's Avatar
Mark Shead
The ST tb has a diff shape for the idle valve outlet and using it on there normal inlet will cause this to overhang it and leak so it cant be used.
Mark
Old Nov 22, 2011 | 07:34 PM
cossiedave's Avatar
cossiedave
thats why its taking so long ordered one from some one else and had it in 3 days
Old Nov 22, 2011 | 07:39 PM
ajamesc's Avatar
ajamesc
The manifold was ready for posting after a few days! the problem is with the throttle cable bracket that he is waiting for his fabricator to make as the cable linkage is different on the throttle body im using and he says he hasent done many using that set up so im waiting for the bracket
Old Nov 22, 2011 | 07:50 PM
BRAMMER's Avatar
BRAMMER
Out of interest what benefits does using either a 500 or ST throttle on a Hart inlet have over using std size 2/4x4 throttle? which mine has got
Old Nov 22, 2011 | 08:13 PM
flannigan's Avatar
flannigan
[QUOTE=ajamesc;5708148]did you order it with the throttle cable bracket and if so did he say you would have that in a week[/QUOTE
he said that he had the guy from the machiene shop bring a bracket over yesterday wich he ok'ed and that they would be ready for collection next week ?
Old Nov 22, 2011 | 08:15 PM
flannigan's Avatar
flannigan
as far as im aware none unless you plan to go over 600 bhp
Old Nov 22, 2011 | 08:24 PM
J1mbo's Avatar
J1mbo
B1mbo
None brammer, as above. I've said it on here before we've seen 700bhp on a standard tb. And 726 to be exact on a rs200 evo engine which has a smaller than 2wd tb!n
Old Nov 22, 2011 | 08:31 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
A table i have found for the hart inlet.
Std TB + Hart then RS500 TB + Hart
4000, 278lb/ft 215bhp - 280lb/ft 230bhp
4500, 325 & 276 - 331 & 291
5000, 350 & 331 - 360 & 334
5500, 347 & 364 - 365 & 377
6000, 340 & 388 - 356 & 407
6500, 335 & 411 - 352 & 435
Figures from a engine dyno
Steve
Old Nov 22, 2011 | 08:38 PM
J1mbo's Avatar
J1mbo
B1mbo
Lol!
Hold on a second. At 230bhp its picked up 15bhp, all at 4000rpm
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
Chopshop85
Sep 12, 2015 06:42 PM
