fitting st170 engine mk3 escort
Old Nov 20, 2011 | 12:26 PM
xtatiana01x's Avatar
xtatiana01x
Default fitting st170 engine mk3 escort
hello im watching a st170 running gear on the bay, and need to know will it bolt up like a zetec with modding the cvh manifold,
because it mounts different in the focus, so wondering if the bolt holes are the same in the block as a zetec.
thanks
Old Nov 20, 2011 | 01:33 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
It'll bolt in the same as a blacktop zetec (same block), exhaust port spacing is the same as a cvh, but the inlet is unique to the ST, so use the std st170 inlet or make a custom one
Old Nov 20, 2011 | 03:46 PM
xtatiana01x
Ok looking to just use full at running gear the just use the cvh flywheel and clutch
Does that mean I can mod the cvh mount to fit like a zetec, or will I have to weld a new mount point
Old Nov 20, 2011 | 03:50 PM
Oranoco's Avatar
Oranoco
My brother has fitted an ST170 motor in his missus Mk6 Escort GTi and if I said it wasn't straight forward it would be an understatement. That was swapping from a silvertop Zetec. Loads of people advised it would be a piece of piss but we had to have a number of bespoke parts made for it to go in and work properly
Old Nov 20, 2011 | 03:57 PM
xtatiana01x
Ok I was looking at running the cvh, box, shafts, clutch and flywheel
Full st170 engine side of things so need to know how to get it mounted
Old Nov 20, 2011 | 04:03 PM
Oranoco's Avatar
Oranoco
Box will mate straight up as we reused the IB5 from the GTi with no issues. Mind you we're not expecting it to last all that long once the throttle bodies are fitted.
Are you planning on using the VVT or dumping it off and dialing the cam in manually?
Old Nov 22, 2011 | 04:48 PM
xtatiana01x
Looking at using the st170 loom and ecu so no throttle bodies
Old Nov 22, 2011 | 04:51 PM
xtatiana01x
Oh just read my first post made a mistake
Using st170 manifolds not cvh ones but wanted to know if you mod the cvh engine mount like you do on a zetec
Old Nov 22, 2011 | 05:56 PM
zippyobrien's Avatar
zippyobrien
Need to fit a black top style mount to the shell
Old Nov 22, 2011 | 09:53 PM
xtatiana01x
How much would that cost to get done I can get it painted
Old Nov 22, 2011 | 09:56 PM
luke19790_3's Avatar
luke19790_3
you can mod the cvh bracket to fit the engine
Old Nov 23, 2011 | 04:46 PM
crazycage's Avatar
crazycage
like so.....
Old Nov 24, 2011 | 09:45 AM
xtatiana01x
Crazycage can we sent our mount to you to do, and I need the flywheel modding
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
orionguy
Aug 6, 2015 07:36 AM
Old ford
Jul 31, 2015 06:50 AM
