mondeo power boost valve
got my hands on a power boost valve with full fitting kit, now im going to fit it this weekend is there any real difference in acceleration and power levels , whats the safest pressure to set it at and is there any hidden gremlins after fitting it that will need to be tweeked. cheers
W reg mondeo 2.0 zetec (black top)
you will gain zero power from it. all it is, is an adjustable fuel pressure regulator its completley unnecesary and they have also been known to burst causing the engine bay to set on fire, my advice dont fit it
It's not a waste. I've run one on prev cars. You won't get a gain in power, but the main benefit if these is the chafing pressure rate. It will create the set pressure 1.7 times faster (iirc) than the standard one. You WILL notice improved throttle response from it if you set it up correctly.
Matt
Matt
should be ok to fit mate has used them for years on his cars As far as I know it boosts the fuel rail pressure so you get a bit more squirt for each injector opening but I think your car has adaptive fueling as part of the ecu setup which will try an negate the extra fueling it detects and dial it out.
JK12
33
Apr 26, 2021 12:09 PM
