2wd Fuel Pressure - Aeroquip
Im in the process of buying the parts to renew my fuel system with Aeroquip fittings. Im buying new Hardline tubing to run under the car, and was planning on buying some of these the convert the ends to JIC. The list shows the maximumun pressure these can handle is 100psi. Is this enough for stage 3 saff running a 044 pump ??
cheers in advance
cheers in advance
JK12
33
Apr 26, 2021 12:09 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
